Question about Kicker ZX10001 Car Audio Amplifier
My kicker amp turns off
I have a kicker zx1000/1 amp pushing 2 cvr 12" subwoofers and i have 1.5 farad capacitor hooked up also with a jensen flip out indash dvd player and when i turn my volume up to any thing above 20 and the bass hits the amp will shut off for about 5 seconds and come back on it does not go on protect it just turns off what could be the problem
  • 631 Answers
It sounds like you may have the load impedance too low. How many voice coils per woofer? How many ohms is each coil? If you have DVC woofers, are the coils for each woofer wired in series or parallel? Are the speakers wired in series or parallel. Let me know if you need me to clarify anything.
Posted on Oct 05, 2007
  • Cheechaar337 Apr 04, 2012
    I have the same problem with the same amp n am only pushing one 12 l7
    I have take. Off my cap off it worked a lot better but my lights would dim too much n the Amp would still turn off only if an in idle but while driving it'll be fine
    I them installed a second battery thinking it was my voltage n now I could play bass while idle but it still turns off if I have the car off with the key turn back
  • David Bogan
    David Bogan Mar 29, 2014
    check your wiring if the wiring is too small or nowt allowing enough amperage the amp will not push at min you have to run 2ga wiring
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
2 kicker cvr 12's in prewired kicker box with 1 wire terminal, kicker cx1200.1 amp. Whats the best way to wire this combo?
Well you really can't run both speakers on one term. because you will over heat the amp , unless your amp is rated at twice the capability of your subs , Then if so , Try positive to one sub , then neg. to the other sub , then bridge the remaining positive to the remaining negative terminal , But it is really best to get a two channel amp for your subs !!!
Sep 23, 2013 | Kicker Comp CVR 12 x 12 Car Subwoofer
How do i wire a single 12" kicker cvr dual 2 ohm
Simple power fom amo to power on sub. Ground on amp to ground on sub
Feb 28, 2013 | Car Audio & Video
I hooked up a 2-Ohm dual voice coil 800 watt max 12" Kicker CVR subwoofer and 4-Ohm single voice coil 1000 watt max 12" Kenwood KFC subwoofer to 1000 watt Kenwood Ampilifer. After hooking it up, the Kicker...
off the same amp? you have two way different sounding speakers man. you can buy 2 identical speakers from the same company and brand and series and they will play differently every time. you have 2 speakers with nothing in common so you will hear a difference and maybe interference because of the different ohm levels.
Apr 14, 2010 | Kicker CVR12 Car Subwoofer
How to wire a 2400w amp to 3 12s subs
if the amp is a 2 channel, u could either bridge them all, or if you wanted to, you could hook 2 speakers to the two seperate channels, and then hook the other one to the negative on one channel and the possitive on the other. if this wasnt what you meant, just, try to tell me more about the amp... thanks
Dec 05, 2009 | Kicker CVR10 Car Subwoofer
I have an Audiobahn A8000T amp and 2 12" Kicker CVR (DVC) Dual voice Coil. The Subwoofers are 2OHM a peice. What is the best way to hook this all up to run a 2 OHM load to my subs?
This is a link to Kicker for your CVR12 Subs...if you have the 2 ohm version (2 ohms per voice coil) and you have 2 speakers ....you will need to wire EACH speakers voice coils in series to get 4 ohms from each speaker and then wire the 2 speakers in parallel.....as in....2 ohms in series with 2 ohms = 4 ohms....both speakers wired same way, then in Parallel with each other = 2 ohm load. Page 2 of this link gives examples of both series and parallel wiring of your speaker.
http://www.kicker.com/sites/default/files/2006CompVX.pdf
If you are still not sure as to my description of ' How To',
PLEASE respond and I will attempt to explain it EXACTLY via wiring directions.
Nov 18, 2009 | Kicker CVR12 Car Subwoofer
I have 2 alpine r type 12's hooked up to a kicker crossover and a NRG 2200 800 watt amp. they are wired series and parallel. when i turn it up the subs sound like the are fluttering. what is going on.
well my friend either your amp is not powerful enough to push your subs or you have a sub that is shorting out cause i just had the same problem with my 2 15 kicker cvr competition subs
Nov 04, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
I have 2 12 in kicker cvr tryna drop to lower ohm
http://www.colomar.com/Shavano/dvc_spkr_wiring.html
Use the above site for several wiring schematics on dual voice coil speaker hookups. It will show how to wire for different impedance.
Also, I think the CVR 12's come in 2 ohm and 4 ohm impedance. See if you can check yours to determine which you have....
Jun 28, 2009 | Kicker CVR12 Car Subwoofer
Hook up
how do you wire up a kicker cvr 12
Jun 14, 2008 | Kicker CVR12 Car Subwoofer
2 12'' cvr kickers
ya u allreadyfound ound out the problem u have factory amps there u go after market
Feb 27, 2008 | Kicker CVR12 Car Subwoofer
Car Audio & Video Logo
356 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
