Question about Protron PLTV-32 Television
Not wall mountable???
I see a place where screws could go in the back of this, but it only looks like a cheap plastic shell, nothing metal backing it, ie. bends when i touch it. Anyone know if this is wall mountable or not? Did not find anything about it in my manual.
  • sherribaby May 07, 2008
    Bought Sylvania 37" LC6637LCT tv...then bought mounting bracket....only to find out that there are no screws or holes on back of tv to mount this....Sylvania says it is mountable, but there is absolutely no way these tiny holes will hold up the TV....any suggestions??
I have wall mounted my Protron. Here is a website that has a picture of this wallmount: http://shop4.outpost.com/product/5374318?site=sr:SEARCH:MAIN_RSLT_PG There is a metal plate screwed into the back (near the top) of the set. The wall mount attaches to the back of that metal plate. Only problem is, I can't remember if that metal plate came with the tv, or with the mount. This mount can swivel up, down, left or right up to 15 degrees. It worked well for us. If you don't go with this mount, make sure the one you decide to get can handle the weight, and has VESA compliant mounting points. One word of advice, save the screws (and label it), so if you ever decide to use the base again, you can find it. I'm learning that lesson the hard way.
Posted on Oct 05, 2007
SOURCE:
How to wall mount the monitor
You have to take the desk stand off first. It's covering the holes.
Watch this video at about 5 mins 30 sec. You can see the screw holes when there's no desk stand attached.
Sep 14, 2014 | Televison & Video
I am having trouble to remove the interior panel of tailgate. I was able to remove the two screws underneath the handle from the panel but unable to remove the two screws beside the latch locker at th
These retainers are like a rivet or dry wall plug take a small flat blade screw driver and a Philips (or star) lightly pry up on the shoulder of the middle pice while turning counter clockwise the centre should back out remove it then with the flat blad gently pry outer pice from hole good luck hope this helped you
Dec 26, 2013 | Honda 2001 Odyssey EX
Lint screen won't go down all teh way.
take the metal duct out that the lint filter slides down into,stick the metal strip through the hole in the side of the duct so that when it's in the bottom part of strip is flush up against the back side wall of duct and it should have like a half inch or so sticking out of the hole,but before you stick it in clean out the duct and with a thin long screw driver open the plastic cover that the filter slides through and poke out any lint in the slots that the filter slides in.so unplug the dryer,remove the bottom panel of dryer,remove the lint filter and screws that hold the lint filter duct in place they are 1/4 inch head screws,clean out the duct and the side slots up above the duct in the plastic area then slide the metal strip into the hole so that the bottom part that you first put into the hole fits flush up against the back inside wall of duct and the top of strip will be flush to the outside wall of duct and like around 1/2 inch or so still showing.hope this helps
Jun 02, 2013 | Kenmore Elite He5T Dryer Heating Element...
My tv is a 42 inch toshiba model#42HL67 im trying to remove the base from the tv so that i can mount my tv
Hi, I have looked into whether or not this t.v. is wall mountable. The only way to tell if this is possible will be to look on the back of t.v. and if wall mounting is possible then there will be 4 screw holes approximately 15 inches apart forming a square. If these " mounting holes are not present then there is no way to mount the wall bracket. Second if holes are present there may be a protective plastic cover at the top of the table top stand where it meets the t.v.. It more than likely is just a snap on type situation and a little bit of prying will pop it off revealing the screws. I hope this has been useful, and thanks for asking FixYa, Good luck- Prodzilla.
Apr 20, 2011 | Toshiba 42HL67 42 in. LCD Television
How do i get the plastic panel on teh back of my frigidaire freezer off--there aer no screws--there is a little round button off center on teh panel. I have used hair dryer adn the whole panel comes...
The panel you are trying to remove im guessing is near the top of the freezer. Do not remove that, as it is ONLY an air tunnel that leads from lower down the back wall. Removing this plastic panel could damage it. That METAL panel is held in place by about 10 screws. also, the temperature control is usually clipped on this back wall, and NEEDS to be removed from the back wall to remove the back wall from the freezer. there is usually a styrofoam cover around this control behind the back wall, keep this in one piece. If there is a problem with your freezer, it will have nothing to do with that upper plastic panel, as again, it is only an air tunnel
Dec 10, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
I have a Salter 307 kitchen scale. Are there any instructions for disassembling this unit? Removed 6 + 1 screws and I still cannot open the unit. Please help!!
How to open up the Salter 3007 Aquatronic Digital Scale:
1. Look for a hole (covered by a label) on the bottom of the device, not far from the L-R centre line, and about 1-3/4" from the front. Peel back the label and use a small cross-head screwdriver to loosen the screw that can be seen though the hole (needs about one turn, no need to remove it). Place the scale upright, and rotate the weighing pad slightly in a clockwise direction. This will disengage the tabs on the plastic pad which hold it to a metal base, so that it can be lifted off. 2. Remove the six screws recessed around the bottom of the scale. 3. Place the scale upright and gently "snap" apart the top and bottom shells (catches molded into the left and right ends). Be *** VERY CAREFUL *** when doing this as the display is held in place on a plastic bridge by the upper shell. When this is removed the display is loose except for a flexible plastic printed connector strip (which links it to the circuit board). It is *** all too easy for this strip to break away at one end or the other ***.
Apr 01, 2010 | Salter 3007 Aquatronic Digital Scale
How do you wall mount a 37" olevia tv...there are only two holes showing for screws at the top of the tv and nothing at the bottom
Hi Is it a 32" or 37" as the one you mention at the top is a 32". The product spec doesn't state that it is wall mountable, some aren't. However, providing your two holes are structural and not just into the plastic, what I did with my non mountable TV in a similar predicament to you, is to buy 2 steel rulers off ebay,(£2) drill holes in them to enable them to be screwed to the back of the TV, then where the two existing holes are at the end, used for haning the rulers up, I made into slots so that the ruler now looks like it has a hook on the end. I then drilled holes in the wall corresponding to the same on the TV, shove rawl plugs in and then the screws leave about 5mm - 8mm head out of the wall in and literally just hook the TV on the wall. Fit nice and flush & saves a fortune in rip off brackets too.
Dec 06, 2009 | Olevia LT32HVM 32 in. LCD Television
Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Jul 22, 2008 | Sylvania LC320SS8 32 in. LCD Television
Broken Hengis
if you havn't had it for a year,, you might be able to take it back where u got it and get a new one,
Dec 09, 2007 | Nintendo DS Lite Console
Protron PLTV-32 Television Logo
241 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
