Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony WEGA 42" LCD TV
There is a blue light at the bottom of the screen. It seems to be getting bigger. What should I do?
Re: Sony WEGA 42" LCD TV
Sny wega 42" wil not turn back on. Red light flashes
Posted on Mar 12, 2008
Your speakers are too close to the tv, the magnets create the blue spot
Posted on Jan 17, 2008
  • 1,284 Answers
If these are oth LCD projection have them looked at. The light engine will need to be relaced and has an extended warranty on some models for this case. Call Sony with the serial and model to verify and they can tell you in your area who is a qualified Sony servicer. Circuit City can handle these if they are covered by the light engine warranty.
Posted on Jan 08, 2008
0 characters
3 Points
Is the model KDF E42A10 sony grand wega covered in the class action lawsuit for yellowing on the screen. There is a yellow blurring creeping up from the bottom of my screen on my tv
As it has a tube, there seems no actual reason for that. The glass cannot change optical characteristics nor the coating on the inside of the tube. Maybe it is an optical illusion.
Mar 28, 2011 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony trinitron srs wega 36 inch colour is going blue gone already is it worth fixing?
hello eightythreem!
some pro's and contra's...
Trinitron tubes are the best ever built picture tubes - long life, best contrast and sharpness, brilliant colors, etc thou u never get with any modern lcd screen. otherwise the big form factor is uncompareable with todays thin screens. also the brand itself and in your case the wega model is a name on its own high standard. anyway i would recommend you to let your tv check by a local service cause it sounds like a electronical problem - let them tell you how much aproximately fixing will count - before they repair it - so you still can decide is it worth or not. hope to helped a bit.
Feb 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hello, I have a Sony FD Trinitron WEGA #KV-36FV310 manufactured around 03'-04', all of a sudden lately i've noticed a ghosting blue line spiraling up the screen,i only notice it when the screen gets dark,...
It's the return of the line, it should be cut off completely. To make it invisible again the cutoff point for the blue cannon should be adjusted (practically this means - turn a potentiometer) - all it takes is a screwdriver and the necessary knowledge. How much it will cost - that depends on how expensive your repairmen are
Dec 04, 2009 | Sony FD Trinitron WEGA KV-36FV310 36" TV
Blue light on top center of TV picture
It sounds like it needs the Optical Block replaced. It can be fixed but it will be expensive and a good bit of a tear down to replace. Cost wise $600.00 or so for the part. Sony has had a lot of issues with these Optical Blocks and you may want to call them to see if it qualifies for a recall repair.
Their Customer # is 1800-222-SONY
I hope this helps,
Nov 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
32 inch sony wega flat screen but not a lcd
try to check horinzontal output. and vertical ic.
Jan 11, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony wega tv problem
no,most of cases is only cause of loose contact.
Oct 18, 2007 | Sony KV-32XBR200 32" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
474 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
