Question about Eclipse (XA1000) Car Audio Amplifier
Stolen deck? I bought a used car which has an eclipse deck in it that is displaying "call 800" when I start my car then when I push any button it changes to "7a200366". What do I do to make it work again?
  • Anonymous Nov 22, 2007
    My car battery went dead and I replaced it. Now all I get is a flashing "call 800" on the display...no buttons work...no audio....eventually it goes to a flashing display " up xxx" "down xxx"
    any suggestions ?
Call the 1 800 nember to get the deck reset
Posted on Apr 24, 2008
SOURCE:
Won't power up. Displays SEC / Help Then SEC / 8D201399 Note the serial number is CD201399. Alan
All Eclipse brand radios have a feature called ESN (Eclipse Security Network) installed. This means a Key CD may be inserted into the head unit so that if the unit is stolen or battey is disconnected from the unit you will have to enter the key CD to unlock the unit.
For example, lets say you purchased this unit from bestbuy. You installed it in your car and you wanted to activate the ESN security feature. You need to choose anyone of your cd's from your collection, lets say you chose The Offsping, Conspiracy of One. Input the disc hit the correct buttons ( I'll explain those later) and your Eclipse 54400's ESN is active.
Now, your 54400 is stolen a week later, the thief will plug in the 54400 into his car and it will show SEC [disc], so he/she will insert a cd and it will say [ERR]. If he or she does this 5 times it will show [call 800] which will lead them to Eclipse customer service, but you will have already called eclipse and told them that your unit was stolen. Whether you get your head unit back is highly doubtful but nobody else will be able to use it.
Now for your answer, to activate ESN:
1.Turn the vehicles ignition on and press the power button 2. Press and hold Radio station preset 1 and the FM-AM button for more than one second 3. Insert the CD of your choice. A [SEC] message will now aooear on the screen and ESN is active. Anytime the unit loses power you will have to reinsert the key cd.
To deactivate the ESN feature:
1. Turn the vehicles ignition on and press the power button or the FM-AM button (make sure the tuner is on). 2. Press and hold the radio station preset button 1 and the FM-AM for more than one second. 3.Once the display flashes [disc] insert the key cd you selected to activate the ESN. The display should now read [CnCl]. The ESN is now deactivated.
To resume normal operation after the power has been disconnected to the unit:
1. Wait for the dispaly to read [disc]. 2. Insert you key cd, if the correct CD is inserted your display will read [---] and the cd will begin to play. If the wrong CD is inserted it will display [Err]. If you insert the wrong CD 5 times it will say [call 800] and then you have to send the unit to eclipse to have it rest. Good Luck!
How to read the Electronic Serial Number:
1. Turn the vehicles power on. Prss the FM-AM button. 2. Press radio preset button 4 and the FM-AM button for more than a second and the display should show your 8 digit serial number. This number is to identify your unit if it is recovered after being stolen. Yep, that will happen!
Keep in mind that the "security code" in a radio basically fulfills this function, ensure that in case of theft, the computer does not work in another vehicle;
I didnt know there was a website to get the radio codes. Before you pay anyone to get your radio security code, I recommend you get on the internet, Eclipse dealers, ask for the parts counter, tell them you need your radio code, have your serial number handy as well as all other numbers off the radio housing.
Or, call 1-800-233-2216 (Fujitsu ten) and they will assist you in the removal of the security code for a $25 charge. the number being displayed is probably the serial number of your unit. If you can remove your radio the SN will be on a tag.
Hope this helps.
Oct 28, 2010 | Eclipse CD3422 CD Player
Call 800 number on my display the cd deck , how can i fix it
you have to call eclipse. your head unit is locked and you have to get tech support to unlock it. if you bought it from someone and just installed it good luck. if you bought it brand new and have the receipt or box you'll be in a better position to get some help but without those you're not going to get too far
Mar 17, 2010 | Eclipse 5440
Call 800 5b501 121
Oh yeah! Eclipse probably has the BEST recovery on stolen players. You call the 800 number, they tell you to send it in, then they give it back to the person who got it stolen from. If that person is you,then call the number and they will unlock it. If that person is not you, then you may have bought a hot CD player.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 23, 2009 | Eclipse CD3422 CD Player
How do I set the clock on an Eclipse 5332
1) press and hold the display button
2) using buttons 1 thru 4 set the time while holding the display button down. ( buttons 1 and 2 adjust the hour, buttons 3 and 4 the minutes...
Dec 21, 2008 | Eclipse 5440
Error
The manual states
1. " An (ERR_) message will appear, then change to a flashing (DISC), then the CD will be ejected."
You will have 5 uninterrupted attempts to insert the correct CD.
2. After the 5th incorrect attempt, the display reads (HELP)
3. If (HELP) appears on the display, press button (6), then the (FUNC) button, and hold them for 5 seconds.
4. Press the (FUNC) button. You will have 5 more attempts to insert the correct disc.
IF AFTER 10 TRIES, AND IF THE CORRECT KEY CD HAS NOT BEEN INSERTED, THE DISPLAY READS (CALL 800); THE UNIT MUST THEN BE RETURNED TO ECLIPSE TO BE RESET. CONTACT ECLIPSE DEALER OR CALL (800) 233-2216.
Jul 19, 2008 | Eclipse CD3422 CD Player
Eclipse 5440 Manual Needed
I had the same problem until a minute ago:
Good luck
Jun 12, 2008 | Eclipse 5440
Eclipse 5443, something is up...
Eclipse used an anti-theft technique where a special CD is required to unlock the unit if it loses power. These were not always set up, and I got lucky where mine was not... You may be able to contact Eclipse about it as it is an older unit, but I wouldn't hold your breath.
Jan 04, 2008 | Eclipse 5443
Setting the clock on Eclipse cd5405 deck
Push the function button once. turn the right knob (SEL) untill CLOCK ADJ shows on the screen. push SEL in one time to lock in CLOCK ADJ and the hours will blink. Turn the SEL knob to set the hours. push SEL again to get to the min. Turn SEL again to set min.
Aug 29, 2007 | Eclipse CD5405
Eclipse 5340 deck
I forget about the security light but I do know about the clock. I believe you turn the deck off and hold display or push display and the clock will come up. Then use the preset buttons for adjustment. I think 1/2 is for the hour and 3/4 are for the minute. It has been a while for me doing this but I think it is right. I just powered mine back up a while back and am trying to find my starting cd. You wouldn't happen to know how to reset this function and start over?
Apr 11, 2007 | Eclipse 5340
Eclipse (XA1000) Car Audio Amplifier Logo
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
