Question about Sony KP-57WS500 57" Rear Projection Television
Green CRT doesn't come on
I couldn't get the color correct so I took the front off the tv and can see that the Green CRT doesn't look like it's on at all. Does this mean it's the CRT or is there somewhere else to look? I have adjusted the screen knob to no avail. The TV shop has told me they would have to replace all 3 crt's and it would be over 1K to fix. Help! Thanks!
  • tejchauhan Nov 11, 2007
    Screen becomes green after 3-5 minutes of switching on,as soon switch on picture is almost ok with all colors but start becoming green green and green.Please assist me to resolve this problem,Thanks
    Tej Chauhan, e Mail address [email protected]
  • amaisano Nov 25, 2007
    I have the same problem... If anybody can help please email me [email protected]
    Thx.
    Problem Solver:
What blink code do you get?
Posted on Nov 06, 2007
  • NCT Nov 06, 2007
    Hey what blink code do you get?
SOURCE:
My sony kp-51ws500 tv screen would turn green and stay on for about 30 sec, then trun off. I adjusted the green screen button on the black box in the front of the tv....via info from this site. It fix the...
Doing the adjustment is not actually a fix, all that does is change the drive amount of the green CRT which allows the set to work but the 3 CRts will be out of balance so picture color will be affected. The only way to repair a bad CRT is to replace the CRT itself. You can get replacement Green CRT from www.tvrepairworld.com
Jul 30, 2011 | Sony KP-51WS500 51" Rear Projection...
Only yellow,blue & green colors, occas hint of red. What are correct settings? middle of gauge,
sounds like degausing circuits bad. unplug for couple of hours. if this doesnt work try waving a heavy magnet in front of tv about 2-3 inches from screen.
Jun 01, 2009 | Philips Magnavox MT1905B 19" TV
Green tint
Check 3.58 MHz color oscillator,, little metal can near large ic,
Also check color output transistors or any loose connections in the output stage
Jan 19, 2009 | Symphonic ST420FF 20" TV
MITSUBISHI 65" WIDESCREEN MODEL WS 65809 (GREEN GONE, SMALL RED LINES)
in the front cover turn up screens on all colors till you see retrace lines, then back them down to where dissappear. enless you know the correct voltage to set it. as for the green. i would try the red crt on the green and see if it looks ok. if so then replace crt circuit or check transistors on crt circuit may also need to change the driver on the heat sync.
Apr 09, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Color problems
green overpowering makes me think you have a crt problem. or even a bad blue or red crt.
Dec 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Adjusting the color convergence
You are going to have to have the convergence IC's replaced, the only way to correct this I'm afraid. Good Luck
Jun 24, 2007 | Toshiba 55H70 55" Rear Projection...
Zenith 25" Color TV - Model A25A23W
Your problem is a bad connection on the CRT socket on the CRT driver board, a bad connection in the RGB driver supply from the video jungle IC or maybe even an intermittant Picture tube. the only way to tell would be to tap on the crt board while the sets playing with a non conductive insterment, and see if it changes. Now there is alot of HIGH VOLTAGE at this spot, so if you have no TV repoair experience Please stay safe and call in a pro to assist you. Good Luck Please dont forget to rate this thread.
Nov 11, 2006 | Zenith A25A23W 25" TV
Sony KP-57WS500 57" Rear Projection Television Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
