Question about Averatec Notebook
Averatec USB ports
I have an Averatec 3200 laptop running Win XP. I have tried 3 different flash drives from different manufacturers. The OS recognizes the inserted drive, and gives them an appropriate name in Windows Explorer, but when I try to drill down into the drive's files, I get a message that the drive needs to be formatted. I tell the system to format the drive as a FAT device (I've also tried FAT32). It appears to be formatting, but after the blue squares move across and to the right side of the indicator, I always get the message "Windows cannot complete the format." Is there something that I should/could do to reinstate the port or whatever? Thanks, Tom Johnson
  • Tom Johnson Oct 05, 2007
    I walked through the steps you suggest above, and carefully so, but without success. The laptop recognizes the USB flash drives, but when I am in Windows Explorer and click on the mapped drive letter, it still asks me if I want to format the drive. I do not. And I know the flash drive is working because I have copied files to them from another computer's USB port. Strangely, I can connect an external USB hub to any of the three ports on the laptop, and even run an external mouse through that external hub or via the ports in the laptop. So it seems that some of the circuitry is working, but not with any of the three flash drives and one memory card reader I've tried.
    Most perplexing, but thanks for your suggestions.
    -tj
    Brigadier General:
  • 6,966 Answers
Hi, A couple of things you can try: 1. In your Device Manager, un-install all USB instances then reboot. Win XP will auto detect and auto install back the USB drivers; 2. On reboot, again in your Device Manager, all instances of USB Root HUB, right click, click on Properties, Power Management tab, un-check "Allow the computer to turn off this device to save power." 3. Download, install and use to format flash drives the HP Drive Key Boot Utility (cp006049.exe) available at http://h18023.www1.hp.com/support/files/server/us/download/23839.html If for some reason none of the above will for you, you may need to install an external/powered multi-port USB 2.0 Hub. Hope this be of some idea/help. Post back how things turned up or should you need additional information. Good luck and kind regards.
Posted on Oct 05, 2007
SOURCE:
Does the Averatec 3200 Notebook have an usb2 port?
Yes, it has 3 USB 2.0 ports
Click here for a full review and specifications,
http://forum.notebookreview.com/notebook-news-reviews/6860-averatec-3200-notebook-review-pics-specs.html
Hope this helps. Thanks for using FixYa.
Jul 13, 2011 | Averatec 3200 Notebook
1 usb port cant detect a flash drive but can detect other usb devices
I'd say its the flash drive thats faulty .Try it in another computer to see if its recognized.If not the flash drive itself is bad.That port recognizing other devices says it functioning as intended.
Oct 24, 2010 | Averatec 3200 Notebook
USB ports stopped working
go to the Averatec support driver page and download new drivers for the USB. Sometimes these are listed as "chipset" drivers, which is a set drivers bundled into one.
below is a link to where you can download files
http://www.user-guides.co.uk/Averatec/AveratecCDDownloads.asp?keywords=Averatec%20Download%20Manual%20Drivers%20CD%20ISO%20PDF
Aug 30, 2009 | Averatec 3200 Notebook
Targus mouse not recognized
What is the OS of your computer? This Targus mouse would work with Win 98, Win 2000 and Win XP. Vista was not mentioned. And if you are running Windows Vista for you laptop, then that could be the reason why it was not recognized by the computer.
Is this the wireless optical mouse? If yes, you need to follow the steps below to isolate the problem:
1. Connect the USB receiver into different USB ports of the computer.
2. Replace the batteries with the fresh ones.
3. Try connecting the mouse into different computer to see if you've got a defective mouse.
If you've tried everything and got the same problem, you may need to refer to the manufacturer, because I'm not sure if this mouse is a Plug-n-Play device or if it needs a driver.
Have a great day!
May 26, 2009 | Targus PAWM001U Mouse
My averatec series 3200 notebook cant detect my usb device
The flash disk could be faulty, especially when it draws too much power, and this will cause the USB ports to shut down and the other USB devices won't work until the faulty device is removed.
Mar 11, 2009 | Averatec 3200 Notebook
Averatec 3280 unmountable boot volume
You can install Windows XP from your CD drive, you may have to change the boot order so you can boot up from the CD first.
Nov 22, 2008 | Averatec 3200 Notebook
Reinstalling OS
if you have this laptop to be honest if you are going to reinstall just go ahead and use a new copy of windows xp. Averatec carries no support for that laptop at all not even the bios. This laptop's drivers are all covered in vista, but if you use windows xp the drivers will all install but you get the generic brand video drivers. you are going to have to try both and see which one you like. vista will allow the computer to run normally just give the laptop an upgrade in ram to 1g and it should run great as a single core processor.
Sep 08, 2008 | Averatec 3200 Notebook
Laptop Averatec 3200 PC Notebook
Try having the problem devices turned on and plugged into the USB port(s) and then start or restart your PC.
This should cause Windows to recognize them and install drivers if available from its library.
It may also ask for an installation disk if it cannot identify the device.
Jun 30, 2008 | Averatec 3200 Notebook
Averatec 3250 laptop
I think you may need to repair your installation of windows XP or if that doesnt work, just reinstall it fresh.
Nov 18, 2007 | Averatec 3200 Notebook
Averatec Notebook Logo
486 people viewed this question
Top Averatec Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
