The fuse keeps blowing, I can put a wire in there and get them to turn on and work fine. But that is dangerous. I tried disconnecting the lights to see if it was that. I was wondering if anyone knew of any trouble areas in this vehicle where an issue can occur.
SOURCE: dash lighting and tail light.
the bulb in the dash went out you need to remove cluster panel near where the light went out
SOURCE: need 1998 mitsubishi 3000gt wiring diagrams
go to gtouk.com and buy a manual all the info ever needed is inside.
SOURCE: Tail light, backup light and dashboard light will not light up??
96 eclipse rs back tail lites and dash wont come on i changed the combination switch ,fuses,relays and bulbs and it still dont work what else can it be?
SOURCE: Need to solve towbar wiring fault for trailer
This sounds a bit crazy, but you do not have a good solid ground to your trailer brake lights. You may have to run a separate ground wire from the trailer to the car. Pull your trailer close to the front of your car, close to the battery. Use some wire to connect your trailer to the battery. Then touch each contact one at the time until you learn which port turns on which light(s). Using the wires, only one in the ground connector and the other in the brake connector. gain access to one or both sides of the trailer lights, use another wire and touch the base of the bulbs to the metal of the trailer if the light gets brighter you need to run another ground wire. Hope this helps FixYa up.
Also all other lights work, just not the tail lights and dash. (blinkers, brakes, reverse, and headlights are all fine)
