Samsung HLP4663W 46" Rear Projection HDTV Logo
Posted on Oct 05, 2007
Loud Buzzing Sound - Rear of TV
The unit is working perfectly and there are no lights flashing in the front of the unit. Picture quality is also excellent. However, there is a loud humming or buzzing sound coming from the back of the unit. Sounds like the fan. When the TV is truned off, the sound winds down.
  • nonnieknows Nov 02, 2007
    TV has been humming for a while now. Three days ago the bulb blew up. Ordered replacement, put it in but the TV still hums. What is causing this?
  • Techie81 Nov 27, 2007
    I hear a loud buzzing sound at the back of my tv. The error in front tells that it is the lamp so I replaced the lamp. I still hear the loud buzzing sound and the lights in front are still blinking. What could be wrong?
A
Anonymous
It is probably the color wheel that needs replacing.
Loud buzzing sound from tv with no picture
It sounds as though your SMPS is seriously faulty and normally one can buy a kit to correct the problem if you are a TV engineer, however there could also be many other reason for the condition that you describe its almost impossible to guess correctly, it really needs a qualified engineer to assess the problem along with he or she having the set with them.
HITACHI MODEL # 53UDX10B has a flashing red light and a buzzing sound
If it was transported likely the set was damaged--one of the three picture tubes used could have been damaged--the flashing light is the set trying to come on and the buzzing is related to whatever is bad.
It needs to be opened and inspected.
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
2helpful
2answers
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Loud rumbling/buzzing for 10-15 seconds and then power goes off
Your Color Wheel needs to be replaced!
Call Mats Electronics for Parts and supplies
1-800-628-1118
3 lights blink and a loud buzzing sound.
Color wheel you can get one at the following link with instructions on how to replace it
Poor picture quality and loud buzzing noise
Sounds like your color wheel is failing they make a loud sqeauling noise when they begin to fail.Run you somewhere around $300-400 to have a tech repair it.
http://the-tv-dude.blogspot.com
Sound messing up on TV
well this may not be that helpful, but if you decide to give up, you can always run the sound through your surround system or plain old stereo, and there are many ways of doing this
Loud Buzzing Sound
Sounds like the cooling fan blades are hitting something (possible worn bearings).
1helpful
Loud Buzzing Sound
since you changed the lamp my next thought is that the color wheel has failed,,,most good road techs can replace it in the home..the cost would be between 220.00 and 350,00 depending on the company...
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
