My daughter just about 10 min ago splashed some pickel juice and some landed on my phone and I turned it off took the battery off it did not seem real wet anywhere but now that i have turned it back on it is set on what says "car kit" and i do not know how to get it off, I can use my phone i just cant hear anything, please help my phone is a flip phone that only says verizon LG the inside says model # vx4500
The same exact thing happed to me. I spashed a little bit of water on the counter and it touched my phone. I turned it off and wiped it down and when I turned it back on & it says' CAR KIT on the front. This is a model VX-5200. What car I do to fix this.The same exact thing happed to me. I spashed a little bit of water on the counter and it touched my phone. I turned it off and wiped it down and when I turned it back on & it says' CAR KIT on the front. This is a model VX-5200. What car I do to fix this.
You can't post conmments that contain an email address.
If it’s an iPhone? Do a hard re start on it! Press both home button & turn off & on switch at the same time. Wait till the screen goes black (it is now off). Wait for 5x mins or so, then turn it on as normal. This resets the software of the phone, but does not delete any of your data
switch off mobile up to 3 to 5 hours without battery then input battery again and connect with charger wait 5 to 10 min then press switch on button this will solve the problem.
if lights flattened battery after 10 mins then its a new battery as no reserve amperage ,as for the lights on the dash i have no idea to be honest without a play with it
this sound to me like at first I thought it was a fuse, as the problem went on it shifted more toward a weak cell in the battery, if a weak cell sits for a little while the battery will not hold the charge in that cell and that will cause loss of power, "its charge", in tne other cells. you had mentioned you used another battery and it ran great but when the battery was removed, things went wrong. You may check to see if there is water in your battery
Well... I would say no.. Not worth battery.. I had the same thing happen to me where my phone wouldn't charge and we bought a new battery for $50.00 and then we find out my phone is shot.. so I would strongly recommend getting a new phone..
no sorry- it is replacement time.but itis covered under the insurance if you have it under water damage as long as it stopped working in the last month.
remove battery and put your battery and cell phone in the freezer for 30 min and lit it dry in a cup of rise for 30 min, repeat the process until it turns on and it's dry
I have nokia 6010, seems to be having similar problem. Tmobile trouble shoot suggests battery contacts, or battery charger, or battery itself as problems. Even better check this out. might help. Oh. might be battery, plug in the charger, battery must have a small amount of charge to turn on, say 10 min. then try to turn on. See if it's charging.
