Question about Nikon Coolpix S1 Digital Camera
Says camera is not connected to computer
Sequence of events that normally works: 1) Connect the COOL-STATION (with camera mounted and off) directly to the computer using the provided USB cable. 2) Turn the camera on. 3) PictureProject opens, and you are then able to transfer pictures. This is not happening. Now, when I turn the camera on, nothing happens. I tried opening PictureProject and clicking "transfer" to transfer pictures, but it tells me nothing is connected to do any transferring from. This has not happened before. I will mention that this is my first time using PictureProject on this computer. Normally, I use a different computer. PictureProject has been installed on both computers. What am I doing wrong?
I had this same problem and got this response from Nikon. I was using Windows 2000 with a L11.
The Coolpix L11 has 2 communication languages it used to talk to the computer and only one of them works with Windows 2000. You will need to make sure that the USB setting is set to Mass Storage. You can get to this option by going to the Setup menu of the camera. Go to your Shooting Mode and press the Menu button. Highlight Setup Menu and press the OK button. Highlight Interface and press the OK button. Highlight USB and press the OK button. Highlight Mass Storage and press the OK button. Turn off the camera and plug it into the back of the computer and then turn it back on. At this point the computer should recognize the camera. If at this point it does not recognize the camera, make sure you have fully charged batteries and that you are using an approved memory card.
Posted on Dec 22, 2007
    Problem Solver:
  • 13 Answers
I'm assuming that you are using a Windows based machine? If so, try another computer. If the camera is recognized when you plug it in, you have a software / driver issue and it's not in the camera. Just plug the computer into any other computer and don't bother with the software.
Posted on Oct 05, 2007
SOURCE:
Can I get the video off of my Sony Handycam DCR-40 without the docking station? It broke, so I want to know if I can connect it to the computer directly? I'm not willing to lose the video we've taken, so...
I bought my DCR-SR40 used (just camera) and I have the same problem. Downloaded the instruction manual from sony and discovered the only way to connect to a computer is through the
Sony Camcorder Docking Station
#DCRA-C162
and a Special USB Cable!
Jun 02, 2010 | Sony Handycam DCR-SR40 Camcorder
Creating dvd from JVC Everio
What kind of file is stored on computer, what extension (eg *.avi)
Jun 01, 2008 | JVC Everio GZ-MG21 Camcorder
DI 624 Was working ,disconected , reconnected work no more.
If you connect the computer to the modem , does it works ?
If it works then modem is working. now connect the computer and modem to the router.
open the set up page of the router. change the Internet settings according to the ISP.
Click Here for more information about router and networks.
Jan 10, 2010 | D-Link Computers & Internet
Hi. I have a Packard Bell Store & Save 3500 320GB external USB drive with power pack. Acer Laptop TravelMate 4220 with XP Pro SP3. Connecting the 3500 hangs the laptop. I read somewhere previously that...
The sequence you plug in the hard drive shouldn't matter. I would click Start -> Run and type:
eventvwr
Click okay. When the Event Viewer loads, click Application. Do you see any errors associated with the times you plug in the drive? Also, check the System events and look for the same thing.
If I were you, I would replace the cable connecting the computer to the external drive. If that doesn't work, I would get another external enclosure and transfer your drive to it.
Jan 24, 2009 | Computers & Internet
Can't find the plug
its located under a rubber piece on back or side of camera just lift rubber piece its there!
Dec 09, 2008 | Sony Handycam DCR-SR42 Camcorder
Cable needed to connect SNY DCR-SR40 Hndycm N DCRA-C162 Handycam Station to computer
There are 2 cables,
  1. A-V Connecting Cable P/N 1-831-553-11
  2. USB Cable P/N 1-829-579-41
attached with Handycam Station DCRA-C162. Hope this info is helpful to you.
Aug 12, 2008 | Sony Handycam DCR-SR40 Camcorder
Photo numbering
I have found a solution, albeit for MacOS X (v10.5)
1) Take a dummy picture. 2) Connect the camera to the Macintosh computer. 3) The camera is mounted as a "NO NAME" disk. 4) Open the subfolder "100NIKON" in the folder "DCIM" 5) Rename the "DSCN0001.JPG" picture to "DSCN5050.JPG" 6) Eject the camera disk. It is done! 7) Take your picture, and delete the dummy one.
As far as it goes, it seems to work for me. Number sequencing will start at "DSCN5050"
AB
Jul 06, 2008 | Nikon COOLPIX Cameras
Hp all in one
Try the follwoing steps, i m sure that it will start working bcoz i tried the same steps and my printer started working:
  1. Turn the power to the computer off.
  2. Press the power button to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the power button to turn the product back on.
  6. When the computer restarts, try the scan again.
  • If the issue is not resolved , try some other troubleshooting:
  • Connect USB cable directly to the computer and then restart the product and try to scan again
  • If the product still does not work , try some other steps:
  • Connect the USB cable to a USB hub or a docking station for a laptop. 1. Restart the computer and the product and try to scan again.
  • If the product doesnot works after connecting the USB cable directly to the computer , follow these steps:
      1. Reconnect the USB cable.
      2. Try the scan again.
        • If the product worked when the USB cable was connected directly to the computer, but does not work after reconnecting the USB cable in the original configuration, there might be a problem with the hub or docking station. Either leave the USB cable connected directly to the computer, or contact the manufacturer of the hub or docking station for troubleshooting.
      If the product does not work after connecting the USB cable directly to the computer , follow these steps.
      1. Replace the USB cable.
        • If the product does not work with the new cable, continue to the next solution.
    Now, if this doesnot work, there is a conflicting USB device connected to the computer
    1. Disconnect all other USB devices from the computer except for the keyboard, the mouse, and the product.
      • The issue would be resolved now and teh answer is that the computer might not have sufficient power supplied to the USB ports to detect multiple USB devices. HP recommends installing a USB powered hub to connect multiple USB devices.
May 28, 2008 | HP DeskJet F380 All-In-One Printer
USB device unknown
Make sure you are connecting directly to the computer's USB port, not through a hub. Try disconnecting other USB devices before plugging in the camera. Check the manufacturer's website for updaded drivers: if all else fails, a reinstall of the camera's drivers may be in order.
Mar 01, 2008 | Sanyo Xacti VCP-HD2 Camcorder
I found this on another site. You have to set the camera itself to Mass Storage mode in order to work with Windows 2000. The steps are below. As soon as I did and plugged the camera back into the USB cable, Picture Project recognized the camera as connected, installed the mass storage driver for it and requested a restart of the PC. Able to access the memory card and download pictures.
On the camera itself, unplug the USB, turn it on and...
Press MENU....
Press ▲▼to choose SETUP...press OK...
Press ▲▼to choose INTERFACE...press OK...
Press ▲▼ to choose USB...press OK...
Press ▲▼to choose MASS STORAGE...press Ok..
Press MENU to exit...
Then plug it back into the USB cable.
Good Luck
Dec 20, 2007 | Nikon Coolpix L11 Digital Camera
Nikon Coolpix S1 Digital Camera Logo
114 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
