Question about RCA HD52W59 HDTV Projection Television
RCA HDTV blurry
My tv is about 1 year old. Today while watching the tv, the picture became distorted. I see 3 curved colored lines (green, red & blue) across top of screen, picture is blurry, almost like the way something in 3-D looks if you're not wearing 3-D glasses. Also, the screen is black in the same curve shape at the top of the screen above the curved colored lines and also at the bottom of the screen below the lines. Any clue as to what in the world this is???? Thanks
  • 1,030 Answers
Re: RCA HDTV blurry
This indications that you have a problem with convergence. first try to go into customer menu...setup....convergence. and see if the convergence will adjust.. if it wont then you have a problem with the convergence cuircit boards.
Posted on Dec 07, 2007
    Problem Solver:
  • 9 Answers
Re: RCA HDTV blurry
As C E T stated, replace the FL231 fuse on the deflection board. It is the middle one of a group of three brown, rectangular looking boxes just right of the flyback transformer (two Red wires connected to it).
Also, it is very important to check the solder connections on the Flyback Transformer. Apply new solder if you see any cracked solder.
If you can solder and identify components, this is most definately a DIY fix.
Posted on Nov 01, 2008
Re: RCA HDTV blurry
I have also had the same problem and my tv is just under 2 yrs old
Posted on Jun 21, 2008
Re: RCA HDTV blurry
Posted on Nov 05, 2008
Re: RCA HDTV blurry
I also had the same exact problem where I had the 3 lines at the top that were bowed downward, and my tv looked 3D. I went into the setup page, and I was missing the convergence part. well we ended having to call RCA about it. of course our 1 year warranty was up. we only had the tv for 1 1/2 years. So they gave us the number to a repair man. he was very rude, and told us it would cost us $200 just for him to come to our house (the guy lives like 5 miles away) anyway we ended up calling another guy that literally lives right around the corner. so apparently The convergence fuse blew in the panel board in the back of the tv. This is something you CANNOT fix yourself. He ended up fixing that, and tuning all the colors in our tv for only $75, and he was here for over 2 hours. well apparently he for the first time fixed an RCA tv that had the same problem 2 weeks ago, and it took him over 1 week to figure out what the problem was. in the long run RCA sucks, and they are selling crappy tvs that are not put together properly.
Posted on May 23, 2008
  • 208 Answers
Re: RCA HDTV blurry
Most convergence failure in these RCA models requires the replacement of the convergence power supply pcb. There is also a cp fuse on the deflection pcb that will open and cause this problem.
Posted on Feb 07, 2008
0 characters
3 Points
Letters and numbers are 3d and curved picture
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
RCA Projection TV Model HD61W66
convergence power supply not working , there is a mini fuse close to the flyback thansformer , 400miliamp at 250 v resolder the flyback and replace this fuse , there is 3 fuses it look like small squer brown color is the one on the middle , normal repair $200 - 300
May 07, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
RCA 52" Model D52W23 Color Distorted
its not due to the fuse.its the problem of the ic on the maIN BOARD of the tv just check out for the faulty on the main board with multi meter and replace it.
Dec 19, 2008 | Sony KP-51WS520 51" Rear Projection...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Mar 07, 2008 | RCA P52937 52" Rear Projection Television
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
1,954 people viewed this question
Top RCA Projection Televisions Experts
The Wyzzyrd
D. E. Hev
Ron Dufek
Ron Dufek
Are you a RCA Projection Television Expert? Answer questions, earn points and help others
