Question about Philips 43PP9202 43" Rear Projection Television
Convergence i need to know what i need to fix my tv's convergence problem. things like part numbers and discriptions for the parts. i have looked at alot of sites and am unfamilier with the simiconducters and things of that nature. called a few shops and would like to if i could get away from paying almost $450.00. Thanks a million.
    Genius:
  • 1,153 Answers
If you look in the back of the set, you have 2 big boards at the bottom, the one on the left has the convergence amps on it. These are the STK's standing up on a heatsink. These need to be replaced and the return resistors also in that area. You can look for part # on the IC's and visit MCMelectronics, bluestar-online, tritronics, etc and find the part. Be careful if you don't know how to solder the IC's out and the new ones in.
Posted on Oct 05, 2007
I am getting a blurry picture that kinda makes it look like a 3d movie without the glasses on with alot of blue
The tv have a problems known as a convergence pictures problems.Tv have any colors lines R,G,B mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than the tv convergence board it is the causes and already dead to have many of these convergence pictures problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures many problems.The tvs shops will cost u like $300-$350 for parts and labors.
Sep 07, 2011 | Panasonic Televison & Video
Samsung hcn4226wx/xaa red color out of focus
Ok first of all, the convergence board you are looking for is no longer available from Samsung, probably because of the large failure these boards are having. The only thing to do though would be to replace the convergence amp IC's on the convergence amp board. this will involve locating the convergence amp board, going to http://www.samsungparts.com, entering your model number, without the /xaa prefix. Locating the list of parts for this TV set, and getting the right convergence amp IC's for this TV set. The numbers for the convergence amps are STK-392-040. You will also need to get the service manual for this TV set to perform touchup convergence, as well as to realighn the magic focus into the memory of this TV set. If you have the ability to solder and unsolder, you should have no problem replacing thes convergence amp IC's. But i will have to say this, about 45% of these TV sets do still have a problem after the convergence IC's are replaced. this is usually due to the burnt ground return resustors on the convergence board, so be perpared to know how to read a scematic diagram in the service manual and to trouble shoot the board. There is no simple repair to this problem I'm afraid, with this Samsung TV set. But , if at any time, you feel lost in the repair of this set, do not continue, and call out a pro to assist you in the repair of this TV set. Good Luck with the repair of this TV set.
Jun 26, 2007 | Samsung HCN4226W 42" Rear Projection...
Hi i have a jvc tv model av-56wp30 it has a red line in the corner of the tv what seem to be the problem and will it cost me alot of money to fix?
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,B,G mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board it is dead.The tv convergence board,must require repalcing 2 STK convergence ICS and some or all of it resistors too.The tv convergence board is fix,will solved ur tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 04, 2010 | JVC AV-56WP30 56" Rear Projection...
My tv has double writing and picture and the picture has alot of red and green in it what should I do or what does that mean
Look at some photos if they show your problem you have a convergence trouble.
Total parts cost if parts purchased on EBAY will be under 30 dollars.
I can step you through the fix but if convergence it means both of the STK-392-110 CHIPS need to be replaced.
The hard part here is getting at them--I can tell you the best way to do this as I have fixed over 1,000 sets with this kind of problem.
Other than the chips there are a few resistors around them that need to be checked--easy and they are cheap parts if needed.
Let me know your skill--I will post photo of the chips and what typical convergence problems look like.
If this information is helpful rate this solution as "very helpful" as I do this here for free.
SD TECH
Aug 11, 2010 | Toshiba 42H81 42" Rear Projection...
I have a Toshiba rear projection TV model # 50H71 for about a month the tv would randomly pop off (lose sound and picture) for about 45 seconds and then come back on now th picture is reduced in size by...
Good Day,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number
23905094 (STK392-110) using the revised “T” version IC Part Number
23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
Thanks for choosing FixYA, Big Irish
Nov 22, 2009 | Toshiba TZ50V51 50" Rear Projection...
The green color is off. I am thinking that it is the auto convergence. I want to try to fix it my self (I love to do these kind of things) but I do not want to buy the wrong part.
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
To Find the IC's look for 1 or 2 large (4in x4inx1in) aluminium heat sinks. the part # is labelled on the face of the IC itself
Sep 30, 2009 | Zenith R57W46 57" Rear Projection...
Sony xbr-52in projection tv show double picture's
It sounds like a convergence problem. A fairly common reason for thisproblem is the convergence chips have failed. They are usually referredto as "STK" chips since the model number of these chips start with STK.I will put a link to another part of this site where someone has postedpictures and a link where to get the parts should you decide to fix ityourself. Look at Ecullier2012's posting. Jean's posted site will notfix this problem. Hope this helps you out. Let me know.
http://www.fixya.com/support/t1684874-screen_blue_green_green_red_outlines
Mar 08, 2009 | Sony KP-51HW40 51" Rear Projection...
Toshiba 42h82 for parts
Put it on eBay. Write a good description, sell the whole thing "local pickup only" if you don't want to ship it. OR you could offer the thing as parts on another site such as Craigslist.
I suppose you could let us know here what the listing number or where.
Question though? If it's just the convergence, why don't you fix it or have it fixed?
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Jan 05, 2009 | Televison & Video
Kp-57ws500 sony projection tv convergence problem
Sony convergence problems
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into ptscorp.com and have them repair it.
Jan 22, 2008 | Sony KP-41T65 41" Rear Projection...
Convergence
corbey1984,
Look for bad pico fuse feeding B+ to convergence amps,two are
hiding under the heatsink amps are on, more fuses in power supply ...............................What part # did you use and what price / mfr. ?.............................T
Cris1983,
please verify your model number on back of your tv..........T.
Nov 30, 2007 | Samsung PCL5415R TV
Philips 43PP9202 43" Rear Projection Television Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
