I have the replacement part for a broken handle on my Bosch dryer, but the screw heads are not Phillips... what tool do I need to get theses screws in and out? Thank you.
SOURCE: Bosch Dryer venting
i think you will find that one of these caps should be off and preferably connected to a vent hose to go outside the house. the reason they are blowing off is that the air has nowhere to go
SOURCE: Bosch Dryer WTMC3321
Hello Teambrant, the screws are a T-20 torx for the door and T-25 for the hinge. You can use the T-20 for both if you need to. Open the door all the way, remove the screws, then as you close the door it will come off. This kit will have all the parts needed for the kit. You will have to have the kit to reverse this door. The plastic retainers slide down, I use a pop sickle stick to push them down.
SOURCE: A bird has managed to
Take off the back and save on time, the front is plastic notches and one screw buried inside on the blower! Go to www.apdepot.com and punch in your model as looking for parts, there good and giving good pics.
SOURCE: asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
SOURCE: On my bosch shu66 diswasher the error code
as long as it is sealed and you should also make sure there is not water in the white plastic pan under the dishwasher..
