Our Canon (bought in 2004) is set up with a USB port, rather than a firewire. I hooked it up to our MAC, in hopes of transfering our tapes to DVDs and didn't get a response...no camera detected. When I looked carefully at the port on the camera (5prongs) I noticed that one of the prongs is bent. Is something like this repairable? If so, any idea on the cost? Or could we get the parts somewhere and do it ourselves? I'd really like to be able to continue using this camera rather than purchasing another just because a prong is out of place...otherwise the camera works just fine. Thanks for your help.
THIS PORT IS SOLDERED INTO BOARD.. YOU MIGHT BE ABLE TO BEND IT BACK VERY CAREFULL=Y. BUT MOST LIKELY IT WILL JUST BREAK OFF. THE PINS ARE VERY FRAGILE.U MIGHT WANT TO CHECK WITH WWW.PARTSTORE.COM FOR PARTS BUT THIS WILL BE HARD TO FIX
You have to use a firewire connection in order to transfer your videos. The cambera will not transfer the videos through the usb ports. There is no specific driver for Vista, and this isn't a driver issue. Use your firewire port and cable, and you should be fine.
Good luck,and hope this helps.
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.)
Unfortunately USB and Firewire use two completely different protocols for handling the data transfer, so it is not possible to just buy an adaptor that will change one to the other.
You can however buy fairly cheap plug in Firewire cards that will fit a notebook, providing you have an expansion socket (PCMCIA, CardBus, ExpressCard). Just try Googling '"Firewire for notebook"
No such thing s a dumb question, I transfer from my Canon XL1 to my Mac IBook with firewire all the time. You have three choices:
1. Buy a cable with two different ends - one that will fit your camera (the tiny one so small it is hard to insert) and one that will fit the Mac. Your Mac should have two different types of firewire ports - the semi-round one and the square one that looks like a USB port, but isn't. The symbols are different for firewire ports firewire and USB ports. But all firewire ports, regardless of the configuration will have the firewire symbol and all USB ports will have the USB symbol. Either firewire symbol port will work. I have two different firewire ports on my MacBook G4 and use them both, I keep a bunch of firewire connectors around. They usually come with outboard hard-drives in various configurations. Sold en Ebay or at computer stores
Solution 2: Feed your firewire through an outboard drive that will accept the 400 firewire (many do) and then take another firewire, say an 800, from that drive into your computer. I always capture to a hard drive then edit from there. The idea of a firewire bus is that you can connect a number of drives in parallel and mount them all. Available for as little as $69.
Solution 3: Buy a firewire port card for you MacBook which slips into a slot on the side, and gives you connectivity with the 400. It also frees up your main firewire port. I bought one on Ebay for $24 that came with all the adaptors.
I was pulling my hair out too until I figured out the system.
I CAN HELP ON PARTS OF YOUR PROBLEM. FIRST, MOST CAMERAS DOWNLOAD IMAGES THAT ARE COMPATIBLE TO WINDOWS SYSTEMS, NOT MACS. FOR DOWNLOADING TO A MAC I'M AFRAID YOU'LL HAVE TO GO TO THE MAC WEBSITE. I'M A WINDOWS VISTA USER.
AS FAR AS THE HDMI PORT, THAT PORT IS AN OUTPUT PORT TO CONNECT TO A HIGH DEF. TV. YOU DO NOT WANT TO FORCE ANY CABLES INTO YOUR CAMERA ETC. CONSULT THE CANON WEBSITE FOR INFORMATION ON DOWNLOADING TO MACS. A STANDARD USB CONNECTION SHOULD BE FINE TO DOWNLOAD. I HOPE THIS HELPS SOME. SORRY I'M NOT UP ON MACS, BUT I'VE BEEN WITH WINDOWS SINCE WIN3.1 OR EARLIER. GOOD LUCK!
Unfortunately, the Canon Z950 only offers transfer to your pc via firewire (Firewire/IEEE 1394 DV Terminal). Therefore your computer would need to have a firewire port.
firewire is also called 1394 or dv port-card can always be added to older computer to support-cables are 4 pin to 4 pin or 4-6 pin-cam is always 4 pin -mac and most towers 6 pin-laptops are 4 pin-look for a port that looks like usb but has a trapezoid shape end
Digital video on the ZR400 is transferred to a computer only via the DV out port, which will connect to a firewire port on a PC or a Mac. USB will not transfer video, only images to and from the card.
