Question about HP Pavilion dv9205us Notebook
Downgrade Hey i wanna downgrade my laptop from Vista to Xp how do i get all the right drivers for XP? can you help me find the drivers that i need and were to get them?
    Brigadier General:
  • 6,966 Answers
Hi, The XP drivers for your laptop are available at the HP site http://www.hp.com/. Click on "Software & Driver Downloads" leftside near the bottom, enter your product "Pavilion dv9205us", click on "Microsoft Windows XP". May I suggest that you download them now even if still running vista and then burn to a CD or copy to a flashdrive. That way when you have downgraded to XP, the drivers are readily available. Hope this be of help/idea. Post back how things turns up or should you need additional information. Good luck and kind regards.
Posted on Oct 05, 2007
SOURCE:
I unable to install Xp in my compaq cq61-132tu. The install option just doesn't get highlighted. Also, i don't have another computer.
I assume you are attempting a "downgrade" to Xp from Vista, since this laptop does not come with XP.
From the Compaq information page:
  1. HP does NOT support XP for consumer notebooks, so if you have any difficulties regarding XP, do not expect HP will help you.
  2. HP may demand you to install back VISTA if you have hardware problem to troubleshoot it.
    An option to consider-put your original Vista hdd away and install new one for XP.
  3. Some of the notebook features may not work in XP due to uncertified licenses pointed in this guide.
  4. Microsoft has released three (3) Service Packs for XP, use only SP2 for the first trial. Why? Since many of XP drivers are released based on XP-SP2.
  5. Always make Vista Recovery cd/dvd before downgrade to XP. see it here
  6. You have a folder with drivers & programs that may prove very helpful after XP downgrade.
    Copy folder C:\Swsetup to DVD Before formatting your hdd.
  7. If you have a pre-SP2 XP cd, get the full SP to Integrate with Nlite: SP2 Nlite HERE
The help guide for downgrading is here. There is a lot of information on this process written there.
However, if what you want is a an XP look and feel so you can compute the way you used to, change the Vista to look like XP in the display properties.
If you are trying to run non-Vista software, try running it in compatibility mode. To do this, right click on the program files and select properties and then locate compatibility..
Jan 04, 2010 | HP Presario CQ60-204NR PC Notebook
I want to have xp on my vista gateway laptop
Hello, Its really hard to downgrade from vista to XP on dell laptops. vista and XP use completely different drivers and dell has stopped writing drivers for XP. But still you can downgrade. You need to setup external SATA harddrive from where your XP CD should boot as it wont boot from your current harddrive that has vista. Even if you set these up and downgrade, Since dell has stopped writing drivers your new XP will not work with many new softwares and applications as you wont have drivers for them. I would advice you to use Vista. Good luck, Please rate the solution. ~regards, Jegan
Jun 03, 2009 | Gateway MX6710 Mobile Entertainment...
Drivers for compaq v3702au [winxp]
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP Windows version of the drivers you require and install them.
Use this link to download the drivers
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Apr 25, 2009 | Compaq Computers & Internet
Downgrading vista to xp
Now you need to find a Windows XP install disk that can match the licence number printed on the sticker at the back of the laptop and reinstall XP using your serial key.
You will have to download and install also the XP drivers, you find them on manufacturer website.
See links below on reinstalling XP on a Vista system:
FAQ: Giving up on Vista? Here's how to downgrade to XP
How to downgrade from Vista to XP News
How to Downgrade from Vista to XP
Downgrade Vista to XP pro
downgrading from vista to xp
Feb 18, 2009 | Microsoft Computers & Internet
Downgrade from Vista TO Xp
Hi Bienana,
Steps must be taken in advance. Laptops are different from desktops. They have proprietary drivers that need to be available for boot or bad things happen. For example the CD-ROM won't be there any more. Then how will you load anything?
What you will have is a plastic rectangle that keeps asking for an operating system you can't install.
First, create a boot disk.
Second, create another boot disk.
Test them both. Make sure the CD works.
Now for some alternatives to formatting your hard drive.
Click here for a site thats offering Windows XP recovery CD's to those Vista owners that want XP. The offer is good through July 31, 2009.
Click here For the Toshiba site specifically for downgrading Vista to XP. It's a source for the drivers that inevitably don't get copied, what rights you have for which version and so on.
Both sites will give you some important insight before you take the plunge.
Mike
Dec 01, 2008 | Toshiba Satellite P205-S8811 Notebook
Xp Drivers needed for Satellite U400-138 to downgrade from Vista Home premium
Yes you can downgrade it to windows xp. go to toshiba website www.toshiba.com and from there you can download the drivers for Windows XP. befor installing Windows XP please download the Network driver and save it on a CD or any other driver. Then install Windows XP. Install the network drivers, connect to the internet and install the other drivers required.
Thanks
Oct 24, 2008 | Computers & Internet
Where do I get the Downgrade to XP Pro
generally manufacture dont support downgrade, before downgrading please check for drivers for xp in manufacture website
Jun 24, 2008 | HP Pavilion dv6000z Notebook
Downgrading from vista to XP2
Hey, yes your laptop can be downgraded to xp sp2
But I'm unable to find any drivers for it.
Try contacting toshiba for assistance.
Feb 17, 2008 | Computers & Internet
XP Downgrade
You need to start windows setup straight from cd. To do so you may need to change the boot sequence from bios.You will also need a bootable windows xp cd (not the upgrade version). Setup xp as new installation. Ensure you can get all necessary drivers and software for windows xp.
Hint: Vista works fine if it has enough ram memory, and you wont lose your valid licence and all software provided with vista.
cheers
Feb 16, 2008 | Computers & Internet
HP Pavilion dv9205us Notebook Logo
170 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
