"Fuser not installed error code". Did you have a paper jam in the machine? If so open the right door and make sure that the fuser unit is correctly set. You have two tabs on the end next to them are levers lift them, then pull on the tabs "C1" fuser unit(unit that gets hot) pull on them then the unit will come away from the machine slide it back into the machine making sure not to slam it. Close the machine.
To reset the error code go into service mode "clear 107 stop hold the stop down for 5 seconds" select copy SP then 5810# execute then restart machine. Hope this helps.
