Question about SanDisk Sansa e250 MP3 Player
Prombles Recharging Battery
Oct. 4, 2007, I have sansa 2gb Ipod. Promble is: it will only play 1 1/2 hours of playing time . When I Plug the Sansa Ipod in the wall outlet, the Ipod is saying that it is charging, but when I take the Ipod off of the Criffin charger from the wll outlet, it is only 50% charged, and that's why I'm only getting 1 1/2 hours of playing time! How can I fix this prombe? Thank Gene
    Scholar:
  • 155 Answers
Try upgrading the firmware of the player. If it still discharges quickly it may be the battery contact POP and have the battery replaced.
Posted on Oct 14, 2007
SOURCE:
HI, MY NAME IS ANGELA. I PURCHSED A SANSA MODEL
The Sansa charges via the USB cable. Fully charged, it should be good for 12-15 hours of playing. Be aware that not all computer USB ports put out enough current to charge external devices. If your computer doesn't charge the Sansa, try a different computer. You can also charge the Sansa using other USB charges, such as you'll see for charging cell phones from a wall outlet or a car cigarette lighter.
Jul 23, 2010 | SanDisk Sansa e250 MP3 Player
Download from audible
hi,
Have you tried connecting to the net and then continue to subscribe??
Feb 09, 2008 | SanDisk Sansa Clip MP3 Player
I am trying to download an audio book to the Sansa but it won't load. It appears in Windows Explorer for the Sansa, but on the Sansa itself, it does not appear or play. The suffix of the file I'm trying to...
AAX files can be played by iTunes and are also supported by the Apple iPod.
To the best of my knowledge, the Sansa unit is not Apple Ipod compatible and therefore cannot play it!
You will need to convert the iTunes AAX files to MP3 format ... providing they are not protected!
Dec 03, 2009 | SanDisk Sansa m230 MP3 Player
My sansa e250 not play video files when connect to the system throug sansa video converter it tell your snasa not support video format
my ipod is sansa e250. the problem is im not able to load videos in my ipod.i can see in through system the videos are present in ipod but when i plug out and see in ipod the videos are not there.please give me a exact solution
Nov 15, 2009 | SanDisk Sansa e250 MP3 Player
I cant get videos to my 2gb sansa fuze
You need to use the Sansa Media Converter to convert videos (and photos) to a format your Sansa can handle.
Mar 27, 2009 | SanDisk Sansa Fuze MP3 Player
Added 2gb micro card
The player can read the card, but it is not going to add more memory space to the player. The function of the card reader is to enable your player to play songs that you otherwise couldn't play because the hard drive is full.
-Tha Mp3 Doctor
Dec 27, 2008 | SanDisk Sansa e250 MP3 Player
Service centre
i am not able to play mp3 songs in my sansa mp3 plyer,but i could play recordings.it gets switched off automatically.some times it is not recognise3d by the PC.
Oct 19, 2008 | SanDisk Sansa e270 MP3 Player
Sansa won't turn on after using an ipod "road trip" fm transmitter
Kinda the same thing happened to me. I tried to plug my sansa into my friends iHome and it blew out one of his speakers and screwed up my sansa, which was an e270.
Aug 28, 2008 | SanDisk Sansa e200 MP3 Player
Prombles with charging
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Oct 03, 2007 | SanDisk Sansa e200 MP3 Player
Sansa MP3 player charges, plays while plugged into wall, but not unplugged.
When you plug it into the wall make sure you turn it off and let it charge all the way before you start using it again. see if that helps
Apr 25, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
65 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
