Question about Sony VAIO PCV-W20 PC Desktop
Recovery disks - Sony VAIO PCV-W20 PC Desktop
Down laod xp recovery disk
If you're running Windows XP and Windows crashes or becomes unusable, you may have to run a Windows XP recovery setup disk to make your computer usable again. When purchased, many computers don't come with a Windows XP recovery setup disk, but you can download one for free from Microsoft. The Windows XP recovery setup disk holds the computer software and files that you need to assist you in rebuilding your operating system.
Place a formatted floppy disk in your floppy disk drive. You will need six formatted floppy disks. Visit Microsoft's Download Center and download the version of the setup disk for your version of Windows (see links in Resources). http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=E8FE6868-6E4F-471C-B455-BD5AFEE126D8 Home Edition http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=8030 Professional Edition set up disks for floppy http://www.download3000.com/download_17676.html XP Recovery CD Maker Windows XP Home Edition and Windows XP Professional Edition have their own recovery setup disks and you must use the correct disk for your version of Windows. Click "Download" and then "Save." Find your floppy drive or optical media drive on the menu and click "OK." If Windows isn't functioning at all, you will have to perform these actions from a working PC. Remove the last floppy disk when the Windows XP recovery disk download is complete and place it in the computer on which you need to use it. Shut down your computer and then turn it back on. If your computer prompts you to boot from the disk, press Enter. If it doesn't, you'll have to go into your BIOS to set the computer to boot first from your disk drive. When your computer boots from disk it will automatically start running the Windows XP recovery setup disk from which you can then set up Windows XP. Hope this helps.
Jan 30, 2012 | Microsoft Computers & Internet
Asking for system disk; inserted recovery disk but did not work is system disk different from recovery disk
Yes, system disk is different. If you put in a recovery disk and it still didn't work, your hard drive has failed. You'll need to replace the drive, then put in the recovery disk.
I would suggest taking it to someone who knows what they're doing, since it involves getting into the case and replacing parts.
Jul 06, 2011 | Averatec PC Desktop
I want to replace hard disk of my presario v6700, which has a buitin recovery disk from the company. i made recovery disks already. but when i want to install windows from the recovery disk on the new hard...
This error is when you try to use OEM recovery disks with a non OEM hard drive. The company recovery disks will not work, they do this to prevent software fraud. Sorry to say you will have to purchase a copy of windows and start over :(
May 05, 2011 | Computers & Internet
Formatted acer aspire 5736z with windows 7 ultimate and finished but operating system not loading and takes me to recovery screen tried recovery but still takes me there again and again, tried to boot...
Please take a close look at the disk you are using to install "Windows 7 Ultimate". It is definitely a "Recovery Disk" for Windows 7 Ultimate. You cannot install Windows 7 with a recovery disk. Recovery disk always is used to repair corrupt or damaged files of Windows OS and requires that the Operating System is already installed. You need a "Windows 7 Ultimate" Installation disk to install Windows not a recovery disk for Windows.
Apr 17, 2011 | Computers & Internet
Need a recovery disk for acer travelmate 290
do u have another laptop or pc.
if u have open google then open isohunt then.
1st download nero iso maker
2nd download recovery disk for ur laptop
then u nid a 4.7 gig blank disk then burn the recovery disk
Dec 12, 2009 | Acer TravelMate 290 Notebook
Want to restore HP Pavillion 505 N computer back to original
To do a system recovery without recovery disks (not all machines can perform this without recovery disks) press the power button and immediately keep tapping the F10 button until you enter the recovery console.
If unsuccessful, you will need to boot using the recovery disks that came with the machine.
  1. Place the first disk in the 1st CD tray (some machines may have multiple CD/DVD drives) and start up.
  2. Start the machine and immediately press ESC button to enter BIOS
  3. Select the drive the recovery CD is in
  4. Press Enter
  5. Once the machine boots off the recovery disk it will provide several options
  6. Press R for a standard recovery
  7. Press F for a "destructive" recovery (will wipe out and format hard drive)
  8. Press Q to quit
Once you've made your selection, the recovery process will automatically proceed. It may ask for additional recovery disks which have more software.
NOTE: if you are currently able to boot into the machine prior to recovery you should go in and back up any pertinent files. Both recovery options will wipe out personal files.
A link to this information has been provided below. Best of luck.
Greg
HP Recovery
Nov 04, 2009 | Computers & Internet
Factory settings
I find that your notebook is shipped with Operating System disk and Application and Driver recovery disk.
The steps to reinstall the OS using the OS disk are available in the link provided below :
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00681978&dlc=en&lc=en&jumpid=reg_R1002_USEN
Instructions about reinstalling preinstalled Applications and Drivers are provided in the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00400062&lc=en&cc=us&rule=23097&dlc=en&product=1144546
Reinstalling the OS using Recovery manager if your Notebook is shipped with one.
1. Click Start.
2. Select "All Programs".
3. Select the "System Recovery" option.
4. Select the "PC Recovery" option.
5. This will open a new window with the options "Microsoft system restore" and "PC Recovery".
6. Select the "PC Recovery" option and Click next.
7. Now you see the Windows XP LOGO with Please wait...... message
8. Welcome to PC Recovery screen will appear Click OK
9. Click Next.
10.Then you can see the option " The PC Recovery was sucessfully completed Click Restart to restart the PC or Click Turn off to turn off the Notebook"
11. Click Restart.
Steps to Recover the Notebook from a set of Recovery Disks:
1. As soon as you boot the Notebook with the recovery Disks we can see the following 3 options:
i) Click R for Standard PC Recovery options
ii) Press 'F' to format the Hard Drive and reinstall the original factory settings (All data will be lost)
iii) Press Q to quit this menu
2. Press F.
3. Press Y.
4. Welcome to PC Recovery window will appear Click OK
5. The recovery process will be started and the process will prompt to insert the next recovery disk. Please insert the next recovery disk when prompted.
6. Please insert the recovery disk whenever prompted for and click oK.
7. The message "The PC Recovery is complete sucessfull" will appear.
8. Click Restart to restart the Notebook or Click Turn off to turn off the Notebook.
This will complete the recover process using the set of recovery disks
Aug 09, 2008 | HP Compaq Presario V2000 Notebook
Factory.settings
According to what you have said, you might have created the Recovery disks after purchasing the notebook.Now you are trying to restore the notebook to factory settings, but they are not working.
Even you have tried to F11 options to restore notebook using the Recovery partition of your notebook.
Let me assist you in this regard.
If the recovery disks are not booting, then we have to check if the issue is with the disks or with the CD/DVD drive itself.
To check that, you need to try to boot with any other OS CD. If the notebook is booting with other OS disks, then the issue is with the Recovery disks itself.
Even F11 option is not working, you have to make sure that D: Recovery is not removed.
For your information, if the issue is with the Recovery disks, then you can purchase the Recovery disks from Hp at very low price.
You can order them from the below link:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=500508
Under
CD-ROM order page - Recovery Discs you can order the place order for Recovery disks.
Compaq presario recovery commands
try starting the computer with the disk in the drive, I had to run the recovery disk on my compaq a few years ago, I think the disks pretty much tell you what to do. If you want to wipe it clear and lose everything type fdisk in the start/run prompt field. Then the recovery disk puts it all back to factory .
Dec 08, 2007 | Gateway MX6421 Notebook
Sony VAIO PCV-W20 PC Desktop Logo
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
