Sanyo 24inch TV
I just got a used Sanyo TV, its 24inch and is silverish, an older model. The picture and everything is great, except when I turn up the sound it starts crackling and hissing. This only happens when I turn the volume up, if I put the TV on mute or on Video it doesn't make any noise. You can still hear some audio, but it is very unclear. My question is, is this fixable and if so how much would it cost? The TV is only worth about $50 so would it be worth to fix?
    Genius:
  • 1,153 Answers
Sounds like you have a bad speaker,or at the most the audio amp needs changing. Get old speaker out of another tv or stereo.
Posted on Oct 05, 2007
SOURCE:
What would cause my sanyo 32" lcd tv to have vertical stripes in picture. has good sound and good picture except for vertical stripes in picture
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 28, 2017 | Sanyo Televison & Video
I have a Sanyo Vizon DP42647 that was given to me. Everything seems to work great except it looks like red Kool-Aid was poured on the screen. Can it be cleaned or just pitch it
I think it is more than a Kool-Aid stain. likely it was some kind of heat applied to the screen causing physical damage. How does it appear when the screen is white?
Aug 20, 2014 | Sanyo VIZON Multisystem 42" LCD TV 110-220...
Why does my sanyo dp46848 screen go dark but whites are too bright?
First try to gently push the cable between the main board and the LCD controller (T-CON) board and if that doesn't affect the image then replace the T-con board.
Jun 30, 2014 | Sanyo DP46848 LCD TV
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
CAMPORT STUCK on???
I had ot go online to buy a remote control to use with my zenith concierge tv. It is the same model # as yours. I ended up paying almost 40 dollars for a remote made by lg who I believe bought out zenith. I believe you could problably just get a universal remote and get the same thing accomplished. I can do everything with the remote I ordered except the one thing I wanted it for and that is to turn up the volume. It says on the menu, custom, not preset, but it still will only go up halfway no matter what I do. I heard that you could program the tv to factory settings but I tried that with another remote and all it did was reprogram the remote so that it didn't work anymore. If you have any suggestions as to how I can get the volume to work on my tv, I would appreciate it as well
Dec 21, 2011 | Zenith B25A02Z TV
DP42746 Sanyo 42'' Plasma TV-CLASS ACTION STARTED
Sorry you wont get any help from Sanyo or Wallmart. Buy another TV repair people will take your money.
Jun 23, 2009 | Sanyo DP42746 42 in. Plasma Television
Tv will not turn on
Greetings!
Depending on the model number, there are a number of things that could be wrong. Even within a given model number there are a number of possibilities. I have seen everything from rectifiers to horizontal outputs to bad electrolytic capacitors to bad solder connections kill these things. If you are skilled and experienced these are a few things to check. If you do not have repair experience then please stop, put the back on it and get it to a repair facility. I rarely have estimates declined on these because you can not replace it for less than most repairs will cost.
Rob
Jan 14, 2009 | Sanyo DS25390 TV
Sanyo tv model ht27546
our year old tv plays wonderful then it will turn green an the after a while it will go back to normal .we were told that some stores put a chip in it so that after about a yr it will do that.the picture is great but then the screen turns green,what can we do to fix that?
May 03, 2008 | Sanyo HT27546 TV
No channels above 47
That works great except I can get the tuner to program any channels above channel47. Is this a limitation of this older model TV yes there is limitation in old tv. is there some setting I can change in order to get more channels using the tv tuner? in INDIA what we do is put a remote control ckt which gives us about 250 channels. of course we replace tuner also called hyper tuner along with remote ckt or replace whole kit which are cheaply available.& serves the purpose. hope this will help
Oct 03, 2007 | Televison & Video
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Ekse
