Question about Samsung CLP-300N Laser Printer
Noise When printing the printer makes a load clicking noise, it seems to do it only for a short time, any clues
  • 1 more comment
  • nataelena Apr 03, 2008
    mine makes the same noise but does not print at all... help!
  • bigstilton Sep 15, 2008
    After unpacking and starting the printer I have noticed that the printer clicks a lot during printing. This happens on every page and there are a series of about 4 x 10 regular fast clicking noises. It doesn't seem to coincide with paper movement. Review of the product that I read before purchase suggest this printer to be very quiet so I am concerned that there is a fault.
  • lesterow Dec 12, 2008
    My problem just started after about 6 months.  Makes loud clicking noise before it prints.
If its the same as mine its a problem with one of your toner cartridges, if you pull them out you will see that on the back of the "barrels" there is a cog. When inserted this cog is turned by another inside the machine. The plastic on the cog on the toner is very weak so sometimes the teeth will get chewed up a bit. it has never caused me a problem with print quality (just really annoying)and i imagine this is your problem. if you are worried about damaging your printer then pull out all of the cartridges to find the offender with the chewed up cog and replace it as i imagine having it isn't healthy but as i say, its never caused any problems other than the noise.
Posted on Aug 20, 2009
6ya staff
SOURCE:
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
My 06 Nissan Xterra just started making a loud clicking noise after driving it in 4wd for a short period of time. It seems to come from the front driver side wheel area. The noise lasted for about 2 days...
Have someone check the u joint in the cv shaft for that wheel.. they make a clicking noise when 4wd is engaged.. it puts a load on the shaft.. .. often cheaper to just replace the cv shaft
Jan 23, 2018 | Nissan Xterra Cars & Trucks
HP 8600 makes clicking noise takes long time to start printing
Solved!
Found a misfed page jammed inside the printer on far
right side ( by the ink service station) - after removing the
"hidden" wad, the printer no longer makes "clicking" sounds
and prints right away!
Officejet Pro 8600
Feb 18, 2013 | HP Officejet Pro 8600 Premium e-All-in-One...
It seems that it takes my printer a long time to react to printing an copying and it all seems to make a lot of noise. Is that normal?
Yes it its normal. After hit the print its will take few sec or min. "20 sec to 1 min, depend on the computer speed means ram , cpu speed". Some time printer give a bad noise while printing. Specially cartridge users. But that noise can't come from toner build printers. Its smooth like a butter. what ever, as per your sound you can do one thing, remove the cartridge, and clean the dust from printer inside. After that the noise little bit going down. But if your feel the noise like a metal scrubbing, then i suggest you visit service center and tell them for a service.
Thanks & waiting for your feedback.
Feb 15, 2010 | HP Photosmart Premium C309A All-In-One...
Why is my hp psc 2410 photosmart all-in-one make a clicking noise, when I turn it on? It seems to be stuck in a "cycle". Like the printing carriage (if that's what you call it) is hooked-up.
See if you can press the power button to turn it off, leave it for 5 minutes then turn it on again, if the clicking persists again try 1 more time, turn off, leave for 5 mins then turn back on this time there should be no clicking noise and you should be able to send a print job to the queue and it should print.
If this doesnt work then goto the hp software and purge.
Oct 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
Black ink
Please try the following to resolved the issue:
Run a series of head cleaning
1. Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START, CONTROL PANEL, PRINTER & FAXES then right click on CX3200 printer Icon then select printing preferences
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Mar 02, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Load Noises
If the HP LaserJet series printer is experiencing a grinding or odd noise when printing or on power-up, open the printer and remove the print cartridge. Close the printer door.
If the noise does not recur with the print cartridge removed, replace the print cartridge.
If the noise persists, this may indicate a hardware failure. If possible, isolate and identify the location of the noise and contact a local HP sales and service ofice at the number noted in the product User's Guide . A list of phone numbers can be found at
http://www.hp.com/support .
Feb 15, 2008 | HP LaserJet 1320 Printer
Samsung CLP-300N Laser Printer Logo
225 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
jasbo
jasbo
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
