Question about Uniden Lands Phones
Phone display shows second line in use when it is not
I have Uniden 5.8 GHz phone system. I accidentally unplugged the power converter from the base unit for the main phone (there are three satellite handsets as well). Ever since the display on all the phones indicates that the second line is in use regardless of whether it is or not.
SOURCE:
SOURCE: Main handset won't work; additional handsets do.
Check that you have the larger power adaptor connected to the base unit.
Posted on Jun 09, 2007
SOURCE: Base unit light blinking GE 27831
I had the same problem. Once I read the owners manual I found the charge light blinks to indicate that you have voicemail waiting to be retrieved via telecom provider. Much to my surprise I have a voicemail account I never requested.
Another mystery solved - I now know why I missed so many messages.
Posted on Mar 09, 2008
shaggyrat
  • 1224 Answers
SOURCE: Dead Uniden DCT5280 Handset
if battery just replace battery but the head sets are compatible with other handsets of same ghz say 2.4 you just gotta set in base and let base recognize new hand set these phones are practically built the same way but only with new technology
Posted on May 10, 2008
  • 82 Answers
SOURCE: Uniden 5.8 GHz Digital cordless w 3 handsets interference background noise no matter where we are in the house or which handset we use
This is possibly caused by the internet connection.
Try new ADSL filter.
You need one each per device.
Posted on Oct 14, 2008
SOURCE: Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register? In that case you would select that option and select to deregister the handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
Posted on Mar 05, 2009
My uniden phone says - out of range
I just finished fighting my phone for this same problem.Try unplugging the base for a minute and plug back in. I had a dead battery, changed it, it still said out of range. Next I deregistered it by holding the "off" and # buttons until the menu popped up saying "deregister". I had to select "deregister without the base" to get it to work. After all this, I unplugged the base, and that is what solved my problem.
May 25, 2010 | Uniden TRU9585 Cordless Phone
Phone are 5.8 ghz vtech
may be the frequency problem for noise problem.
pleaSE CHECK IT OUT.
ADJUST THEM AT SOME PROPER LEVEL..
AND THEN TRY.
Oct 18, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
Uniden cordless phone Power Max5.8 GHz.
You cannot have both system working on same telephone line.
Aug 04, 2008 | Uniden Cordless phone EXS9950
No dail tone --but phone line is connected
Hello.
If the dial tone is not heard check the volume. It may have accidentally been muted or turned down.
Is the phone line plugged into a surge protector? The surge protector may have stopped working or blown a surge, a sudden burst of electricity, which may have caused the dial tone in your cordless phone to go. Unplug the phone line from the surge protector then plug it back in and see if you get a dial tone? It could be that the phone line plugged into the surge was loose.
Try a different phone plug, outlet.
If the other phones on that line work OK, disconnect all the phones connected to the line, leave them all disconnected for 3 minutes, and then connect one at a time.
If still a problem and the other phones on that line work OK, give this a try:
Unplug the battery in the handset, unplug the phone line from the base and unplug the electricity from the base. Leave everything unplugged for an hour or two. That way you can get more of an idea of whether your phone will work. After an hour or two, plug in everything.
Hope this helps.
Jan 04, 2010 | Uniden 2.4 GHz Expandable Phone System...
Phone disconnects and shows "out of range of base" during calls
Press "Menu", Select "Handset Setup", select "Select Base", and then on that Select Base screen, move the arrow next to "Auto" and press select. I have been told this should solve your problem.
Apr 25, 2009 | Uniden DECT 6.0 Cordless Phone ID
Uniden PowerMax 5.8 - system busy error comes up & no dial tone
Unplug the power supply to the base of the main handset, wait 10 seconds and plug back in.
Mar 27, 2009 | Uniden TRU546 Remanufactured Dual Handset...
Uniden 2.4 GHz cordless phone won't register to base
Same happened to me. Unplug the base from power and the phone line for 30 minutes. Same for the handsets - all. Take out the batteries. Retry. After it says 'registration failed'. Leave it in the cradle. Several minutes later it found itself.
Mar 10, 2009 | Uniden 2.4 GHz Cordless Phone System
My uniden 5.8 ghz will only ring 2 times. I have
Reset the base by unplugging power from back of base, press and hold the delete key while reconnecting power
Mar 04, 2009 | Uniden DXAI8580-3 5.8 GHz Trio 1-Line...
Phone won't hang up
I solved this exactly problem by doing this:
1) unplug base station from phone line
2) unplug base station from power cube
3) open each phone and disconnect battery (do not replace phone in charger; just let it sit)
4) wait 30 minutes (per instructions from Uniden)
5) reconnect batteries in phone sets
6) reconnect power cube to base station
7) reconnect base station to phone line
8) test: make a call. Hang up. Wait one minute. Pick up line and see if you get a dial tone.
(Basically you're "rebooting" the system. You don't know where the fault lies, so you power down every component to make sure you get it. The '30 minutes' is longer than I'm used to, but after being on hold with Uniden tech support for 20 minutes and finally getting through, the instructions from them were very clear: AT LEAST 30 minutes. OK! I did it - and it worked!)
Nov 27, 2008 | Uniden 2.4 GHz Expandable Phone System...
Open Questions:
RE: Uniden D1384 2 Cordless Phone Handset System;Both Phones Use BT 1008 2.4V 700mAh Batteries Please answer each question separately and clearly without unnecessary information. ---- I have 2 cordless phones, one on the base and the other on the charger. ---------------------------- 1a. Even though the base and charger are plugged in, there is no safety hazard removing the batteries in both phones because only the wireless signal between the handset in the charger and the main base AND the wireless signal between the phone in the base and the base itself will be interrupted-Is that correct? ---------------------- b. If the battery is removed from the phone on the base, can the phone on the charger still make outgoing calls and receive incoming calls? ----------------- c. If the battery is removed from the phone on the charger, can the phone on the base still make outgoing calls and receive incoming calls? --------------------------- 2. For safety reasons, should I be home while a new battery is charging for the first time or is that unnecessary? --------------------- 3. Since there is no safety hazard removing the batteries while the base and charger are plugged in because only the wireless signal is interrupted, is there a safety issue if one of the phones happens to ring while the battery is being removed? ------------------------ 4. Can phones remain on the base and charger once fully charged or does doing that have a negative effect on the batteries? I always place the phones back on the base and charger immediately after use and when not in use. ------------------------------- 5a. Can disconnecting a fully charged battery in order to check the specs on it and then reconnecting it 5 mins later without making or receiving a call reduce the charge meaning that is normal for it to recharge for up to 5.5 hrs once the battery is reconnected and the phone is placed back on the charger OR should the full charge remain the same as before the battery was disconnected because the phone was not used to make or receive a call? --------------------- b. Is it 'bad' for the phone/battery/both to keep removing a fully charged battery OR does removing it just increase the charging time when the battery is reconnected? ------------------------ I appreciate the insight. ----------*Also, My questions are 'spaced out' while typed but appear as a long paragraph when 'updated'-How can my questions appear separated? ------------------------ *Is there an option to receive email alerts when someone replies to my thread (so that I do not need to remain signed in)? ------------------------
Jun 17, 2019 | Uniden Lands Phones
Lands Phones Logo
294 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
