High Tension cable
- 4 to 8 Kohms
- With suppression connector and spark plug connector
- Only remove and install spark plug connector using tool T10029
Ignition coil with output stage (-N70-, -N127-, -N291-, -N292-)
Connection, ignition wires:
- HV1 = Cylinder 1
- HV2 = Cylinder 2
- HV3 = Cylinder 3
- HV4 = Cylinder 4
10 Nm
Connector
5
Knock sensor 1 -G61-*
- Contacts gold plated
- Fitting location: Cylinder block intake side
6
2-pin connector
- For knock sensor 1 -G61-
- Do not interchange
7
Knock sensor 2 -G66-*
8
2-pin connector
- For knock sensor 2 -G66-
9
20 Nm
- Tightening torque influences the function of the knock sensor
10
Spark plug, 30 Nm
- Type and electrode gap See test data, spark plugs.
- Remove and install with 3122B
11
Connector
- 3 pin
12
10 Nm
13
100 Nm
- Use counter- hold tool 3415 to loosen and tighten
14
Camshaft sprocket
- With rotor for Camshaft Position (CMP) sensor
15
Camshaft Position (CMP) sensor -G40-*
16
Bracket
- For Camshaft Position (CMP) sensor
