Question about Toshiba 53H71 53 in. Rear Projection Television
53H71 Toshiba Here is the problem , I have a Toshiba 53H71 there was a blinking red light and it would not turn on i replaced the IC's the TV set turned on and was working fine. After about an hour same problem , i noticed the 851 was blown replaced it , than 850 blew. I replaced both of them now the tv set will go but there will be no picture. There is no more red blinking light problem the menu does not come back nothing , the lamps do not go on? what could be the problem thanks.
  • imfeex Oct 13, 2007
    the metal jumpers are on top of the board or the bottom where the fuses are? is there a number associated it with it on the circuit board i could not locate any of them , can you please be more specific
    thank you.
    Genius:
  • 1,694 Answers
Look carefully at metal jumpers feeding b+ to convergence IC's.
Both will need re-soldering or you will keep having problems.
Let me know how it goes.T.
Posted on Oct 13, 2007
  • Vista Electronics Oct 15, 2007
    In the service literature,follow the B+ supply back from the IC's
    I.e. follow the traces--will take you to the metal wire jumpers.
My Toshhiba 53H71 went black and the red power light keeps blinking. Is it worth repairing.
You can repair it, it is repairable, the problem is power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will helpout in solving the problem....
Jun 15, 2011 | Toshiba 53H71 53 in. Rear Projection...
Suddenly double/triple images, bowed red at the bottom
Yes, the convergence IC's need to be replaced. If you are not experienced in TV repair, I would recommend getting a qualified repair man to do it for you.
Here is a link with instructions on how to do this, if you feel adventurous:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Should you find this info useful, kindly take a moment to "Accept" it. Thanks.
Jul 05, 2008 | Toshiba 53H71 53 in. Rear Projection...
Toshiba projection tv with lines on screen
I have seen a lot of sets where the problem only happens when the set is first turned on---99% of the time one of the two STK-392-110 CONVERGENCE chips this set uses is Flakey--intermittant---The only way to know is replace both of the convergence IC's and see what you have---a bad IC can cause the set to shut down---and sooner or later the set will just shut down and not come on at all.
Let me know if you need more information about this type of repair as I have done hundreds of sets with this type of problem----every one I have ever seen where the convergence was intermittent----replacing the two IC's cured the problem.
REGARDS, SD TECH
Oct 01, 2009 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 53H71
Either the convergence or cracked sautering. Just had my tv repaired but now I have a double blur in the upper left corner.
Jul 20, 2009 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 53H71
omg.. i have the exact same prob...
is it a conindenice that we are all having the SAME prob around the same time?
Jun 22, 2008 | Toshiba 53H71 53 in. Rear Projection...
Tv won't come on
Mine is Toshiba 55 TZ, have it since 98', shutdown and red light blinking problem, search the ned and found out, generally a Convergence IC (stk392-110) problem. bought 2 for $15 at suburban-elect.com (ebay). replaced following direction from http://www.casiasfamily.com/repairlog/tp50h15.html
Open back cover, 9 screws and wirings (pls mark), removed(soldered) a electronic board infront of convergence ic. removed IC (stk392-110) (screwed and soldered).
Replaced everything and voila...! it is now working again..
no more shutsdown and red blinking light. Saves mo $400 for a repariman. of course just be careful with static and stuff.
Feb 29, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 53h71
Convergence amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
Feb 21, 2008 | Toshiba 53H71 53 in. Rear Projection...
IC's
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 01, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 50H81 Re Blinking Light...wont work
best advice is go get a manual book on how to fix tv
May 07, 2007 | Toshiba 50H81 50" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
139 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
