Question about Samsung (SHW-162) DVD RW Dual Layer Burner
Not Reading Disc
My burner was working fine for over a year recording dvd/cd's but within the last wk now anytime i stick any sort of disc in my drive it doesn't read it. When i look at my dvd drive from my computer it looks like there's no media inserted in the drive but there is. Whether it's blank or has something on it it's not getting read. How can i fix this problem?
    Guru:
  • 120 Answers
Probably a broken / misaligned laser. Could also be a bad internal motor, can you hear it spinning when you insert a disc? Theres not a ton you can do really, if you're really skilled and have a lot of time you can realign the laser with a digital multimeter and a screw driver, but you have to be very technically inclined. You're better off purchasing a new one. Newegg.com sells dvd burner for less than 30 dollars new. I hope this has explained your question in detail. If I've helped you please don't forget to rate me. Peter
Posted on Oct 04, 2007
Sony DRX840U DVD/CD RW Burner won't play a DVD!
you hvave to check the compatibility first. next is the location rights to play the movie dvd ., other wise., the dvd locks the play.
Nov 18, 2014 | Computers & Internet
Asus DRW-241st stopped recognizing any DVD's though it still reads CD's. Other then that it seems to be running just fine.
Good day sir, Try to clean it with a CD lens cleaner if problem persist.I recommend replacing your optical disk drive or use it as a slave for reading CD's so that your new ODD will last long. in my opinion most DVDRAM, player etc. can read most formats except Bluray disc. using the device from reading CD,VCD and DVD lessen's the device life span.
sometimes if we rarely use the ODD its already not working.
Jun 29, 2011 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
Cd/dvd stops reading disc half way then stops.loading tray sticks or has a delay
Disc stops playing due to tracking error from either a dirty source cd or a dirty blank. It is not the machines fault. Clean both discs thoroughly before recording. Even non visible dust can cause a stoppage. My Sony recorder does seem to be a little too sensitive to dust but it normally works fine.
Mar 09, 2010 | Audio Players & Recorders
Disc Reading Error
my remote wont work recorder
Mar 24, 2009 | RCA DRC8300N DVD Recorder/VCR
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
DVD RW reading problem
Ok it seems as if the drive may be dying or is dead. You said you used these disc before so the problem is with the media(disc) its with the medium*the drive) I dont think flashing the firware in this case will hely you will need to replace the drive :)
Dec 11, 2007 | LaCie d2 DVD-RW Burner
Lg rh177
Could be the dvd player/lens. The player sucks up dust through the
player's caddy and after a while it won't read discs anymore.
A cd cleaner or a good (gently dosed) blow with compressed air might help.
Oct 17, 2007 | LG RH177 DVD Recorder/HDD Recorder
HL-DT-ST- DVD-RAM GSA-H22N
I Have A : HL-DT-ST- DVD-RAM GSA-H22N DVD Burner That Works Fine With (CD Burning/ Reading) & (Data Burning/ Reading) But I Have A Very WIERD Problem With The DVD : Here I Go, When I Use Any Program To Burn DVD Like Nero, DVD Shrink Etc.. (It Appears That) The Movie Is Burning Well, Because In The Burning Process It Doesn't Says Something Like:Bad Disc, Not Succefully Burned Or Any Sign That The DVD Burner Is Damaged , Also When It Finish Recording You Can See The Data Burned In The Disc By The Lines It Forms BUT !! I Don't Know WHY The Fu$%@@ , When You Test The Movie In Any DVD Player , Comp OR Whatever THE MOVIE DOESN'T WORK.
Aug 01, 2007 | LG GSA-H22N DVD±RW Dual Layer Burner
My RCA 8310 DVD+R/+RW -VCR Combo will not format and record on a +R disc
I purchased this RCA 8310 about 2 years ago. I have recoreded hundreds of dvd's. If I try to use anything but a Imation brand DVD+R, 8+ speed, I get the same error. It will not work with a 16+ dvd.
May 23, 2007 | RCA DRC8300N (DRC8300NWITHREBATE) Burner
Samsung (SHW-162) DVD RW Dual Layer Burner Logo
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
