Question about KDS Radius RAD-5 15 in. Flat Panel LCD Monitor
Screen artifacts on an LCD Monitor
There are indistinct squares of "squiggles" on my monitor screen
I've read that it may be the power supply for the monitor
Posted on Oct 14, 2007
SOURCE:
Black screen
If the notebook is not displaying anything when powering on, but is still powering on (indicated by the power LED lighting up) then you should consider hooking it up to an external display or monitor to test where the problem stems from.
If, when hooked up, nothing displays on the monitor it is a hardware issue with the either the Hard Drive, System board, or LCD.
If, when hooked up, the screen displays normally on the monitor, it is an LCD problem
If, when hooked up, the screen displays with artifacting, vertical lines, or discoloring, it is an issue with the system board/ Graphics card.
Mar 15, 2011 | HP Pavilion dv2000t Notebook
Tip
Monitor buying tips you should know.
Over the years monitors have transformed from those bulky CRT monitors to square LCD screens to stylish flat wide screen LCD's and now to new stylish extremely thin LED screens. On average every PC user spends at least 5 hours a day looking at the monitor. If the picture is fuzzy and not clear enough then there is a very high possibility that the eyes get damaged.
An older CRT monitor
A wide LCD monitor
A newer ultra flat widescreen LED monitor
Monitor Sizes
There are many different sizes of CRT, square LCD, wide LCD and wide LED monitors available on the market at the moment.
If you want an older CRT screen then sizes can range between 14" to about 20", they use the 4:3 aspect ratio.
If you want an older LCD screen then sizes can range from 15" to 19", they also use the 4:3 aspect ratio.
If you want a newer wide screen LCD then sizes can range from 18.5" to about 27" and even larger. They use the 16:9 if they are full HD or 19:10 if they are not ratio.
If you want a newer wide screen LED then sizes can range from 18.5" to about 27" and even larger. They also use the 16:9 if they are full HD or 19:10 if they are not ratio.
Image quality
The sharpness of the image in a monitor greatly depends on your Graphics card as well as whatever resolution you are running at. Nevertheless the quality of the monitor plays an important role.
Here are some of the tips that you should know before buying a monitor.
1. There are three types of monitors namely CRT, LCD and LED. The monitor that looks like a TV is a CRT monitor. In CRT monitors there is a Cathode Ray Tube that shoots electrons into the screen to create the image. An LCD monitor is smaller in width and consumes less power and is healthier if you are going to be spending large amounts of time at your PC. The LED screen looks the same as an LED monitor and the difference between it and the LCD is that it has a much higher contrast ratio resulting in darker blacks and much lighter whites.
3. A CRT monitor is much heavier than LCD monitor as you can imagine by it's bulky appearance. A LCD monitor is very lightweight and so is a LED monitor.
4. The distance between two adjacent pixels in a monitor is called 'dot pitch'. This is measured in millimeters (mm). Smaller the dot pitch the clearer the picture quality. Usually there are monitors with dot pitch varying between 0.20 mm to 0.27mm. Some manufacturers use diagonal dot pitch while most of them use horizontal dotpitch. The diagonal dot pitch is always longer than the horizontal dot pitch
5. Resolution of a monitor has to be considered with care. Most of the CRT monitors have resolutions of 800×600, 1024×768 and 1280x1024. The square LCD monitors have 1280×1024 and 1600×1200 resolutions. Newer wide screen LCD monitors have resolutions of 1600x1900, 1680x1050 and the Full HD 1920x1090. When the resolution is higher the images and text will appear smaller. But you can see more text and bigger pictures in the monitor with high resolution.
6. Another thing to note is the 'Refresh rate'. This rate is usually 60Hz, 73Hz, 75Hz, 85Hz. Refresh rate of 85Hz means the picture on the monitor is refreshed 85 times within a second.
7. The brightness and contrast can range between a low 5 000:1 to a high 80 000:1 in a LCD monitor and an average of 5 000 000:1 in a LED, yes that's 5 million to 1 with a LED. This just shows how much better a LED monitor is to a LCD.
8. If you are a gamer then the thing you have to look at with LCD monitors and LED monitors is the response time. If it is 16ms then this is a very bad monitor for gaming and you will experience a ghosting effect in most games and if it is 5ms then you will have an average gaming experience. What you want to get is a 2ms response time monitor, with it you will have the best gaming experience with no ghosting what-so-ever.
on Mar 06, 2011 | Computers & Internet
Coloured squares appear on screen
Seems to me that the LCD cables are not properly atached.
Double check all the LCD connections.
Your problem will be solved.
Jul 05, 2010 | Sony VAIO VGN-NR220E/S Notebook PC
A red line in middle of screen, traded out with other monitor and thats what im using now
Usually lines, multicolored artifact etc. is indicative of a failing lcd panel or...a loose cable connector. There is no repair for this type of problem other than screen lcd panel replacement or secure the loose connection.
Jan 17, 2010 | Acer 22" X223w LCD Monitor
When I power up my T42 thinkpad, the screen is covered in little red squares. Any idea what this is and what I can do to correct it?
This could be one of two things--a bad LCD screen or a driver problem,
Start the computer in safe mode. It should look OK, but not really great resolution. If the squares appear then, try an external monitor. Are the squares on that? If so, it's your video card which just might be part of the motherboard and must be replaced.
If the external monitor is OK, then it's your LCD screen
If the screen looks OK in safe mode (the LCD screen) then your video drivers need updating.
Jan 01, 2010 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
I came home to find loads of red squiggles all over my monitor. Then 4 big red vertical stripes that look like bar codes. I tried to restart the computer by turning it off, then as it was starting, loads...
Wow llks like the controller died in the monitor the controlles the pixalation and stablilization in this case it looks like if its not under warrenty a new one is in order sorry no quick fix I would appricate nice feedback tho
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | HP Pavilion F1703 17" LCD Monitor
No showing the full screen. Top + bottom 1 and half inches dark
your system display settings are set to a wide screen setting on desk top right click then properties, right had tab display then set the screen size to a square shape like 1024 x 768.
Feb 16, 2009 | Dell E153FP 15" LCD Monitor
Vertical green line somthing like an artifact
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Feb 28, 2008 | ViewSonic VA1703wb Monitor
Moniter
I resolve a similar problem by unplugging the power cord for three seconds.
Oct 12, 2007 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Artifacts on flatscreen monitor
The two cheapest things to do are, firstly, try your monitor on another persons pc, to see if any difference, and secondly try a different mouse as they can interfere with with graphics dpi.
Mar 23, 2007 | BenQ FP91G+ 19" LCD Monitor
KDS Radius RAD-5 15 in. Flat Panel LCD Monitor Logo
365 people viewed this question
Top KDS Computers & Internet Experts
Thomas F. Schneider
Siul Oyaratgam
Steve Allison
Steve Allison
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
