1996 Mercedes-Benz C-Class Logo
Posted on May 02, 2009
Engine starting problem
I have mercedes benz c 220 diesel 1995 model WDB/202/121 ,i have problem of starting the engine , after cranking the engine it starts and automatically it turns off by it self , when the engine is off it shows the EDC warning signal .
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on May 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1641
Points
11
Check to see if your trunk is locked to the far right. mine does not start when it is. 1996 c220
  • Daryl Hall Jun 24, 2013
    Thank you very much. I called the local Mercedes Benz Dealer, talked to the Service Manager and he said to have it towed in so he could check it out. My point is when I read your solution I remember turning the key to right to open the trunk instead of the left like I did yesterday. So thank you for saving me money on towing & the dealer.
1helpful
What is the power of the engine in hp of the truck mercedes benz l-312 diesel 1958 ?
Hi Diego.
1954 is the starting point in creating the new range of trucks by Mercedes-Benz. Everything started with light upgrade and rename of the previous series. The L3500 and L4500 models have received three-digit numeric codes - L311 and L312, which indicated the type of installed engine. The design of trucks has not changed (externally can be distinguished only by windscreen wipers, installed from below, not from above as on the previous version). There was also a four-wheel drive LA version. In 1954, a 4.6-liter diesel engine, installed on fire chassis "L311F", has received a turbocharger for the first time, which increased power from 100 to 115 hp. Totally about 175 thousand trucks of L311/L312 models have been made.
Mercedes Benz L311 L312
2answers
Year of manifactured for the Mercedes Benz E220 CDI, Chassis
Must be a rather new car because the e220 cdi is listed as a first drive on the 2010 copyrighted site that I saw:
http://www.autoexpress.co.uk/carreviews/firstdrives/234603/mercedes_e220_cdi.html
1helpful
Need radio code for mercedes benz c200 1996 Original Mercedes Radio radio SN 287006001x wdb 202020 2f356287 9
call mb ask for service and give them vin number and they will provide you i did the same for my mb.
1995 mercedes e320 does not start. The engine does not catch.
1- If engine is not cranking but hearing a click then
a- Problem with battery.
Try to jump start then if battery is over 5 years, replace battery
b- Solenoid works but not the starter.
Need to repalce the starter.
2- If engine is cranking but not catching on, then the problem is with the Bendix part. it is an intergrated part of the starter.
Replace the starter.
1helpful
My mercedes Benz C 220 stalls when I come to a stop or in park .
Is the AC on? The compressor can take alot of power and make it lope. Engine mounts can make it shake. coils, cap, rotor and wires for tune up at a minimum. EZL if you can find one cheap. MAF also can cause issue. If it is a 1991-1995 check the engine wiring harness as they get brittle and degrade.
2answers
1995 benz oil press. prpblem
the filter might need to be replaced, there's a bypass valve that opens up when the filter is plugged to avoid starving the engine of oil. without the resistance of the filter, oil pressure is low. PLEASE RATE MY ANSWER.
1995 e320 mbz
ihave a diesel e320 won't start
Loss of power in Merc Engine 220 Classic SE
alternator not givinging enough power or as they might call it the gernerator is failing replace accordingly
check to make sure your head gasket didnt blow out
by dropping the oil in oil pan if choclate milk looking head gasket gone
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
xxxxxx xxx
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
