replace the blower motor resistor located on the passenger side were your toes point there are two 9mm screws you will need a universal joint socket to remove the back screw drop down the resistor and remove the red saftey clip and press together the two black pieces together and pull apart. If the problems happens again you will have to replace the resistor again and also replace the blower motor because the blower moter is woren and drawing to many amps. The blower has three 9mm screw and one wire harness. I purchased all my parts thru Rockauto .com
It's most likely your blower motor control module. Easy fix! Remove the kick plate under the glove compartment and the module is right next to your blower motor - remove the two screws and it will drop right out. Disconnect the wire harness (2 wires) and replace. Good luck!
chk the fan speed resistors mounted in the fan housing. You should be able to see the wires going into the box with 2 screws holding the resistors in place. Good Luck.
