SOURCE: Braun 5520 Shaver Stopped Working
The "Braun 5520" doesn't have the 2 screws under 2 small caps on bottom, as described by so many on these boards.
The round plastic plug receptacle 'itself' is the release. (Twist-Release the outer ring.)
Look on the base, where you plug the AC cord in.... Just inside the rim, you will see two small 'recesses', opposite each other, that allow a wedge tool (like a large screw driver) to turn the rim counter-clockwise (left) 45 degrees, releasing the base and housing.
Once this is unlocked, slide the cover off and pop the black retainer cover off to reveal the "PC Board W/Batteries" module/assembly. (Batteries are NOT replaceable by themselves.)
There is a tiny (and I mean "tiny"!) resistor that burns out in the circuit board and causes the majority of power malfunctions in these models.
You can order a new PC Board (with batteries) for approx. $40.00. (+ S&H)
One place is: "http://www.electricshaverstore.com/get_item_5505631_braun-pc-board-w-batteries.htm".
(Fits Models: 5510, 5515, 5520, 6515, 6520, 6510, 6512 - Types: 5505, 5506, 5705, 5706)
Or, find other by Googling "Braun 5520 Circuit board assembly", and/or replace this model with your number.
This button wears out or just fails with time, but is replaceable.
Braun 7526 Syncro Body Housing with Trimmer
$12.99, Fits Model: 7526, Type: 5493, Includes back case, front case with trimmer/switch, side grips and bottom 'plug', http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
SOURCE: Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Testimonial: "very helpful"
SOURCE: The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
SOURCE: hi,
While holding the neck, pull up hard on the charging piece with the blue button.... You will not break it, it will go right back in after...
DO NOT try to remove the whole neck, just the button piece will come up, an inch or two (NOT OUT COMPLETLY) The wire will only allow you to pull it up 1"-2" so dont try to remove it....
Then look inside and you can see a spring, it's not attached to anything it's just resting in a hole. Pull it out and then push the top charging piece back down till it clicks in...
Now it will stay down on its own... I had the same problem and this work around solved it.
