Question about Asrock K7S41GX Motherboard
New K7S41GX wont boot
Like in the previous problem entitled similar i cant get my mobo to boot up the psu fan spins, as does to cpu fan i have the power lights on the front panel but there is nothing on the monitor i have tried just about everything i can to get this thing to work and to be honest im at the end of my tether i have already checked for a busted ram tray tried clearing cmos both with and without battery tried a new psu tried reseating the bios chip please help me as im pulling my last few ramaining hairs out as i type this
  • bigyin Oct 04, 2007
    its straight out the box and all capacitors seem fine and it doesnt requre the smaller 4 pin plug as there isnt a bit on the board for it
    also im using the onboard graphics so i can try to eliminate anything i can at this stage
    the CPU i have has just been tested b4 i got it and works fine
    im stumped...anyone got a hammer i can borrow
    Guru:
  • 120 Answers
If you are absolutely sure that the ram works ok then I'd center in on the processor, a bad processor would have this exact type of response. The only things I've seen do this are a bad power supply or not powerful enough power supply, a bad processor, bad motherboard, or bad ram. Also, this may sound stupid, but make sure the power supply is correctly plugged in. If it requires the additional 4 volt smaller plugs make sure they are plugged. Take a look at the capacitors on the motherboard. It's possible you've "popped some caps" on the board. If this is the case you need a new motherboard. A sure fire way to detect a bad cap is to look at the tops of all the capacitors. If the tops are not flat then you may have a problem. They also can pop from the bottom and leak an orange gel. If any tops of the capacitors are rounded or protruding more than the others than you've found the source of your problem. A bad capacitor(s) would absolutely exibit the exact problems you're encountering. Bad capacitors can be as bad as causing the system to not boot, to as simple as making it impossible to reboot the system and forcing you to shut down. Take a look at this picture for a visual example of what I am refering to http://badcaps.net/images/caps/kt7/image004.png Note in the picture how the bottom of the far left capacitor looks puffed up and isn't sitting flush with the others? Also notice how all of them have puffed up rounded tops? You can really see the roundedness of the tops because they have slits in the tops. I've seen the tops ooze brown /orange/ white stuff too. It's something to definitely take a look at. I know what it feels like to be facing your problem. Oh, one last thing, make sure you aren't grounding the motherboard to the case. I've had that happen to. Try taking the board out of the case entirely and just trying to boot with the ram / processor plugged in. If you can't visually tell if the capacitors are ok if you take some close up pictures and e-mail them to my address at the bottom of my post I will examine them for you. If you have any other questions or information feel free to leave a comment back on this post and I will be sure to reply back to you :) I hope this has explained your question in detail. If I've helped you please don't forget to rate me. Peter
Posted on Oct 04, 2007
  • hb9mfl Dec 19, 2010
    Hi Peter, I have here a board with strange effects and would like to send you pictures but I can see your address. Please send e-mail to hb9mflATamsat.org Thank you Armin
  • 661 Answers
Does this Mobo have an onboard graphics chip/port if so try connecting to that first as the BIOS may be set to try onboard graphics first (setting to change in the BIOS)
  • Gareth Cockram
    Gareth Cockram Oct 04, 2007
    if its not working and you know that the CPU is ok and you've checked the PSU.
    if the board is new, send it back for replacememt as a DOA, they should replace it for you NQA.
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
Nov 14, 2016 | Computers & Internet
Pc not booting, no fans spinning, nothing lights up. HALP
REWIRE THE ELECTRIC WIIRES.SHOULD THAT NOT HELP TRY WITH A OTHER PSU.
Dec 06, 2013 | Computers & Internet
Cooler Master 1000w Silent Pro M not compatible with MSI MS-7548 (Aspen) motherboard?
http://www.coolermaster-usa.com/product.php?product_id=2949
So you're using the same CPU 4+4 Pin x2 power cable on both rigs?
(One of them)
Yes, I see it's a modular cable design, and the CPU 4+4 Pin x2 power cable, can be used as a single 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps4plus4
ALL Yellow wires are 12 Volt (DC) wires.
ALL Black wires are Ground wires.
ALL 12 Volt wires go to ONE single 12 Volt power rail, in the Power Supply, BUT; there is nothing saying an individual Yellow wire may be bad.
This is why I wondered if you are using the SAME power cable CONNECTOR. Same power cable.
Yes?
Then suggest it has something to do with the Active PFC circuit.
http://www.hardwaresecrets.com/article/Anatomy-of-Switching-Power-Supplies/327/6
Not aware of any setting to change in BIOS Setup utility - Power.
BUT, I do not know everything! lol!
IMHO there is no reason it will not work, unless as said; something to do with the Active PFC circuit.
From here let's hope someone who really knows what is going on, will post.
Regards,
joecoolvette
Dec 10, 2012 | Computers & Internet
I seem to have a problem with the power to my computer. After 2 days of searching all kinds of forums I still haven't found a solution. The computer won't power up, no fans are spinning, not a...
First remove the power plug from the smps and press the power switch few time and wait for few minutes the re plug the power connector to the smps and switch on the computer if you still dont have power then you will have to check whether the smps work to test that its not enough to test the voltage in the 21/24 pin you will have to short the green wire and the black wire and see whether the smps fan is working if the fan is not working then the problem is with smps
Jul 30, 2011 | ASUS Computers & Internet
I bought a brand new M4A785-M, I have all compatable parts, even swapped every piece out onto my comp with the same board and boots fine. The comp booted fine before, I swapped the single core Sempron (1.8...
Is your phenom Phenom-X3-8450e or AMD-Phenom-X3-8450 ?
8450e is suported by that mobo but in the asus suport page you wont find 8450.
Check here https://www.asus.com/Motherboards/M4A785M/HelpDesk_CPU/
8450e runs on 65w and 8450 runs on 95w.
Does your mobo run with your old CPU?
Apr 09, 2017 | ASUS M4A785M Motherboard
After psu burned out , can't boot computer with
see your cpu fan connector, weather it is connected properly. to check wether psu is working properly, short the black n green wires present in the psu's mother board connetor by using a single strand wire, and switch on. if the fan rotates there is no probs with the the psu. then u will have to replace the motherboard
Sep 04, 2009 | Gigabyte Computers & Internet
Boot issue with gateway gt5028
I had a similar problem. It turned out to be the CPU. Try fishing around to find some way to try to make the computer "squeak". Like holding a key while it boots. This makes the computer make a warning tone. If it does so, I'd imagine there is activity. If any way possible you can try to test the CPU in a different comp. Oh, and have you done any work on it recently and how long has it been operating?
Jun 09, 2009 | Gateway GT5056 PC Desktop
Asus P5Q-VM CANT BOOT
CPU Should work with board.Try removing cpu and replace in socket check for bent pins if all is well..reinstall.make sure to use pad or silver paste and reinstall fan.rebootRichardm69
May 05, 2009 | ASUS Computers & Internet
Asrock P4i65G Motherboard
If the CPU is dead the problems can be
  1. no power
  2. no fans etc or
  3. power, no beeps (errors)
If the Ram is not compatible it would be constant beeping.
With the board in, and power supply 20pin + 4pin Pent 4 power attached,(#2 and #7 of motherboard layout) remove power cord from power supply.
CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes
system setup information such as system password, date, time, and system
setup parameters. To clear and reset the system parameters to default setup,
please turn off the computer and unplug the power cord from the power
supply. After waiting for 15 seconds, use a jumper cap to short 2 pins on
CLRCMOS0 for 5 seconds. Remove the jumper. Remove heatsink and fan from CPU. disconnect cpu and reseat it. Re-install heatsink and fan. Plug in the power cord. Try to boot up. If it still does not boot and (no power, no fans etc.) problem would then be cpu is fried.
Jun 02, 2008 | Computers & Internet
Asrock K7S41GX Motherboard Logo
680 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
