SOURCE: Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
SOURCE: Question regarding audio connections Akai 30" LCD TV
How to connect External Speakers (with Amplifier) or Headphones to Akai LCD 32LW7?
SOURCE: Connecting Laptop to LCD
It might have something to do with wether the VGA cable has all pins connected.
I think some cables don't have all 15-pins wired.
As soon my LCD TV works I will post the outcome.
Greetz Arno
SOURCE: input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
