Question about Refrigerators
Maytag refrigerator door wont close
I have a problem with the refrigerator door not closing and the door bins keep falling off. I was able to find a repair kit to try and help keep the bins in the door but I was wondering, should the seal around the door be replaced as well? If so is taht something that can be done by me? Thanks
  • 114 Answers
If your door seal is seating flush all the way around the opening and there are no obvious gaps, the door seal does not need to be replaced. It could be related to a hinge or something inside the unit not letting the door close entirely.
Posted on Oct 05, 2007
SOURCE:
Why would my Maytag MFX2570AE 4 door french door fridge motor/fan run constantly?
if the compressor goes off and only the fan keeps working thats broken fridg but fan is not a big energy drainer on bill if the compressor works allways it might be to hot in the room or door is not seald or totaly closed give it a strog push when closing or maybe you have under floor heating so you have to insulate bottom from heat or maybe its not insulatdd well from heat of compressor
May 20, 2014 | Maytag Ice2O MFX2570AE 25.0 cu. ft. French...
Freezer door opens when fridge door is closed
that is common, your pushing air back into the other side and that pops the door. First adjust the ref so that the back sits lower than the front. It will have 2 5/16th nuts on the front behind the kickplate. going left will lower the back of the unit. After that get out some vasoline and lube up the flat sides of the door seal, this will help keep the seal moist and it wont pop open as easy
May 01, 2012 | Maytag Refrigerators
The bolt on the bottom of the refrigerator door keeps falling out causing the door to fall off.
you need to buy a bolt washer, its a little flat ring that you put in between the revolving bolt and the head of the screw. this will help rotate the screw while keeping the bolt in place therefore preventing it from always falling off whenever you open / close the door
Oct 04, 2010 | Refrigerators
Ice is forming around the auger under the ice bin. constantly have water dripping from ice cube shoot
the door that the ice comes down to fill glass is not closing; the ice chute door just above the lever to fiil glass with ice it is either jamed with ice or is broken and needs a new repair kit.you can inspect by opening door and look at approx. 3 inch door that ice falls threw to see if closed.warm air causes ice to form.
Sep 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Door dhute not opening to let ice fall
on the right hand side of the door chute there is a little metal barrel that needs to be attached to the end of the arm that holds the ice door. this is attached to the spring that opens and closes the door chute.
Apr 16, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Freezer door won't seal
its a visual thing inspect and look for somthing not right[ie..door seal torn,door warped.hinge cam broken.somthing in the way food package wise so door wont close.God bless,tom
Jan 01, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Door Alarm
SOMETIMES THE DOOR MIGHT SEEM PROPERLY CLOSED BUT ITS NOT TRY RE ADJUSTING THEM AND SEE IF THAT WORKS ALSO THE DOOR CLOSED CONTACT CAN CAUSE THE BUZZER TO GO OFF FOR NO REASON.
GOOD LUCK.
MOHAMED
Aug 23, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
KENMORE REFRIGERATOR 106.57024601
the problem is most likely the water valve behind the machine. it is closing too slow and letting too much water flow into the icemaker. c30b276.jpg
Jul 16, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Refrigerators Logo
497 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
