Question about HP Compaq Presario V2000 Notebook
Screen (display) light blown
Thank you very much!!! The loose connection was the problem. Unfortunately, now I have another problem. While putting the screen back together I shorted out something in that little rectangular circuit board beneath the bottom of the screen (The one with the thin guage pink and white wires) trying to put the tiny screw back in. It looks like the light on the screen is now blown. Is this repairable or even worth repairing?
  • 457 Answers
I just posted to you on your other enquiry. Can u explain what that light is for u said ligth on the screen....sorry what you mean there
Posted on Oct 05, 2007
it just sounds to me that you have a wire harness probably coming off from the display. maybe it looks connected but needs to be reseated. just have a look at all these harnesses. hope this helps. and check the fuses just to make sure you didn't short something out, because if the fuses are blown, then you'll have to find those loose wires before you put back in the fuses.
Nov 25, 2009 | 2004 Suzuki GSX 1300 R Hayabusa
Monitor goes on then off right away.
The backlight inverter is faulty.
THis means that there is either a loose contact or one of the transistors on the backlight inverter has blown
Jul 06, 2009 | HP Pavilion F1703 17" LCD Monitor
My laptop displays very dark
Unfortunately, (Isay that a lot on this site), your lcd screen is backlit with tiny flourescent lights, sounds like these have been broken not much to do except talk to a local tech and hope that he has an lcd screen to swap or steal parts from.
Sorry my prognosis is not better...
Ed Meyer
May 22, 2009 | Fujitsu LifeBook® S2210 PC Notebook
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
Apr 18, 2009 | Sanyo DS27820 27" TV
Possible backlights not working
Unfortunately the cause is normally the screen itself or the inverter board
May 18, 2008 | Computers & Internet
Intermittent display problem
There's a small plunger just beyond the keyboard which switches the screen off when you close the laptop, this could be sticking. Failing that check the screen cables are secure, reseat the screen
May 18, 2008 | Compaq Presario X1000 Notebook
No light on display
The power wire may have come loose in the connection, or the fuse has blown for some reason. Check your connections and fuse.
Feb 17, 2008 | Car Audio & Video
Lcd screen
Well, you're not going to fix this without opening up the camera.
The LCD screen should have to wires going to it. One is for the light that illuminates the LCD. That one is obviously working. The other is for the LCD itself - it sounds like that isn't. Either the LCD needs replaced, or that cable is loose or damaged. I'd suggest opening up the camera, finding that cable (it will likely be a thinner cable than the other), and checking for loose connections, or an obvious break or sharp bend in the cable.
Unfortunately, even if you find the cable is damaged, I'm not sure you can get it replaced. If you're not confident you can take this apart and put it back together properly, I'd suggest either taking it to a repair shop, or just using it as is. I'd hate to see you damage it further. If you are confident, however, check that cable. If it's good, contact Samsung about a replacement LCD.
Dec 20, 2007 | Samsung Digimax i5 Digital Camera
White display on VX9800
The display contains of two main supplies. One is for the data which gets displayed on the screen and the second one is for a thin sheet containing the led's for light. It appears the the data connection has been lost. It can be due to a loose connection for complete malfunction of the screen. If the connection is not loose then the screen needs to be replaced
Apr 12, 2007 | LG HBM-300 for VX9800 Wireless Headset
HP Compaq Presario V2000 Notebook Logo
29 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
