Question about Dell Axim X51v Pocket PC
Axim V51x My battery drained all the way down, and now the internal battery won't charge (reads 0%). Now, every time I swap batteries, the date and time revert to July of 2005 at 12:00. Do I need to change the internal battery, and if so, how do I do it?
  • RSHIRLEY Aug 04, 2008
    I NEED TO REPLACE THE BACKUP BATTERY
    Guru:
  • 120 Answers
You can get a replacement backup battery right here at pdasmart.com Essentially like you said you've totally drained the backup battery, and it now has to be replaced. The repair involved no soldering, so it's not terrible difficult, but you do have to completely disassemble the unit to replace the internal backup battery. You'll need a good set of screw drivers and torx bits to take it apart fully. Also pdasmart has a repair service they offer. For $25 they will repair the pda for you. For an extra $5 and a couple extra days shipping time that would be hands down your best bet if you aren't technically skilled in electronics hardware. I hope this has explained your question in detail. If I've helped you please don't forget to rate me. Peter
Posted on Oct 04, 2007
I WHAT SAMUNG DRIVER
PHONE TYPE :SGH-T100
Posted on Dec 05, 2007
Flashing 0% battery and won't turn on
I had the exact problem with the blinking top menu. I found that my memory card had gone bad. one i put in a fresh card the camera operated normally.
Aug 27, 2012 | Canon EOS 60D Digital Camera
Why do I lose date/time on Fuji FinePix S6500 digital camera when I change batteries
You lose the date/time because the camera has no power to it to keep the settings. Basically don't leave the batteries out if you want it to keep the date/time. On the other hand it will just sit and run the batteries down just sitting there off. It is a bit annoying but that's why. Most cameras store an internal charge so they can keep the date/time but it is not supposed to last very long, it was designed so you could swap out dead batteries without having to reset the time/date every time. If it is happening on simple battery changes it means something may be wrong with the camera.
May 17, 2011 | Fuji Finepix A510 Digital Camera
How to change the internal battery on an axim x51v
I assume you're losing Time, Date and backlight settings? It's soldered to the circuit board on the x51 series, not a plug in like the x50's. In the x51's, it's not actually a battery, but a part called a supercap. That's a very big capacitor that wolds a lot of charge, technical stuff. Not for the novice solderer, the part's small and the board & other components are very heat sensitive. Check HTCGeeks or Mobilitysite for (too) many details about this repair. EASY WAY OUT: Some dude came up with an awesome little program you install to fake it out. You set it for how long it takes you to change your main battery and then run it any time you need to change it. It automatically records the start time and resets the clock to that plus x-number of minutes it takes you to swap batteries!!!! Waaay cool and a lot simpler than opening it up if that's not your bag!!! You can find it on either of the sites I mentioned above.
Mar 18, 2010 | Dell Axim X51v Pocket PC
My Z812 keeps telling me I need to reset the date/time every time I turn it on, even if I have just done it. Also drawing batteries very quickly (lithium, camera type)
It may only happen enter date and time if you remove the battery in the camera., If your not removing the batteru out of the camera you should not recieved that message, unless battery is out of charge or no power.
You should use this battery Kodak Li-Ion rechargeable battery KLIC-8000. This is a special battery for Z812 camera,
Note: You must also need to purchase a charger for this type of battery.
I guarantee you it will provide stable longer power for on your camera
Nov 20, 2009 | Kodak EasyShare Z812 IS Digital Camera
When charging my axim X30 on the cradle, the on-off light is blinking from green light to amber consistantly... when I remove the device from cradle the device does not turn on at all.. I have replaced the...
It sounds to me that your "original" battery, the one that causes the blinking when charging is completly drained dead, causing it to show an error by blinking the light.
I have one of these PDA's and have never had that problem, I also have a larger battery as well, and it works great. I suggest recycling the other battery, and possibly purchasing another larger one for back up,
Mar 27, 2009 | Dell Axim X30 Pocket PC
Battery ramdomly goes dead after super heating
You may want to look at updating the ROM. There may be a fix in a later version of the ROM
Nov 11, 2008 | Dell Axim X51v Pocket PC
Problems with extended battery
Try to check your phone if the battery connector having lost to contact the battery well. Or the problem came from your battery try to borrow from your friends battery to identify the problem.
Please rate me solved if you like my problem.
Best regards,
Philip
Nov 01, 2007 | Dell Axim X50v Pocket PC
Backup battery on Dell Axim X5 varies on charge left, even after complete charge. One minute it's 100%, then 0%, then 100% again within a few minutes
Install Active Sync latest version off of the Microsoft site. Turn off automatic SYNC ..... change it to manual sync.
Then check the connections on the watch battery----- you may need to add a piece of tape to the battery lid to get a tight connection. Carefully bend out the tab that contacts the battery. Wipe the battery off with a clean rag before installing.
Sep 15, 2007 | Dell Axim X5 Pocket PC
USB Sync Cable
I dont' think so. No other PDA does - it would be quite a drain on the USB port. It isn't like powering the tiny LED in an optical mouse.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Dell Axim X51v Pocket PC Logo
505 people viewed this question
Clive
Clive
Alun Cox
