Question about Royal 160MX Shredder
My Royal shredder is knocking
I was shredding some documents when I heard a knocking sound come from the machine. I figued it may have been overheating so I gave it a rest. When I came back the knocking was still there. I tried to oil it in hopes that it would go away but it is still there. Any idea?
  • 1 more comment
  • Anonymous Dec 03, 2007
    The
    The shredder is knocking, but I don't know how to reset the gears. What does that mean?
  • Anonymous Apr 15, 2008
    mine is the plastic gear 2 and 3 that is broken.makes knocking noise.
Check out the site below for Royal Shredder gears and parts. I had a problem with the first gear coming off the motor and had no problems replacing it here.
http://www.geocities.com/jayrespler2/index.html
Posted on Nov 10, 2008
THere is a main gear right off the motor drive that is nylon and shreds (no pun intended). I have been searching for a replacement without much sucess. PLanned? Maybe.
Posted on Jun 09, 2008
One of the plastic gears is broken.have same problem mine is the 2 and 3 gear.
Posted on Apr 15, 2008
  • 74 Answers
The gears may have come out of whack. With the power off you can try opening the mechanism to reset it. -Vish
Posted on Oct 04, 2007
ROYAL 150 MX WILL ONLY TAKE 2 SHEETS
Have you ever "oiled" the machine.
ALL cross-cut shredders need to be oiled to help clear out the paper dust and debris generated during the shredding process.
Pour some shredder oil across the cutting shafts while it is running and occassionaly put some oil onto a sheet of paper as you shred it.
May 09, 2011 | Royal 150MX Cross-Cut Shredder
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
My royal shredder will shred paper just fine but now it won't shred a credit card. any ideas?
Silly question if it shreds paper fine but....when did you last oil the machine.???
Cross cut shredders need to be regularly oiled..( pour some shredder oil across the cutting blades).
It may just be that the credit card is too thick!
Jan 25, 2011 | Royal 112MX Shredder
HT3SL doesn't feed, so it doesn't shred anymore. Powers on and the shredder makes sounds, but doesn't feed so no shredding.
If it sounds like the motor is running inside but nothing is driving then you have probably stripped gears inside...open it up and contact Royal for parts at 1-800-524-0799.
Oct 17, 2010 | Royal HT3SL Shredder
At a point, when the paper is being feed it, there is a knock and top of shredder is lifted as the the shredding gears try to revolve, then mechanism stops and reverses the gears and stops.
Try holding a piece of paper in the "eyes" to see if the machine runs forward...if it won't then it sounds like something may be broken inside...it will have to be opened up to see if anything obvious is damaged. If you need parts then call Royal at 1-800-524-0799.
Aug 12, 2010 | Royal Office Equipment & Supplies
Royal VF700 won't barely shred one sheet of paper. It givexs the overload red light when 1 sheet of paper has just barely started to be shredded.
Royal. Haven't heard of that brand. Could get in contact with tech service, but it's probably easier to grab a new paper shredder.
Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF700 Cross-Cut Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
My shredder requires about an hour of cool down every time it shreds a load.
do spry lub down in the cutter shoot like WD40. If not do it. If you do there may be a billed up of paper dust in the machine it is a catch 20,22
Oct 24, 2008 | Royal VF-1200MX Shredder
Shredding no more
if the unit is pulling paper thru but not shredding your cutters have separated for some reason. If not pulling paper thru but machine is running you probally have a broken gear causing cutters to no longer turn you may hear a clunking or grinding noise or gear may be stripped if shredder sounds like it is spinning freely. Contact manufacturer for parts availability.
Nov 26, 2007 | Royal CIA 12X Shredder
Royal 160MX Shredder Logo
550 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
