Question about Jl Audio 1000/1 Car Audio Amplifier
Help I have a jl 1000 pushing 2 12" alpine type r. Everytime I turn the volume up the low voltage light turns on and the amp cuts off right after that. What is causing this ?
  • 631 Answers
JL amps are somewhat sensitive to low voltage. Everything has to be perfect in the power supply feeding the amp. I'll assume that you have large enough wire. Check the owner's manual on the JL site. They likely recommend 4g or larger. You need to measure the voltage across the B+ and ground terminals of the amp. If it's dropping below ~11v when you turn the volume up, you need to determine why. Make the same measurements at the battery terminals. If there is significantly less voltage drop there when the volume is increased, check all of the points in the circuit where there could be a bad connection. Look for corrosion, over-heated connection on fuses or at the battery and make sure the fuse is in good physical condition. Some types tend to overheat and melt. If everything looks OK, begin measuring the voltage at each point where there is any sort of connector. If for example, you get a significant difference in the voltage on each side of the fuse, the fuse, the holder or the connections to the holder may be defective.
Posted on Oct 05, 2007
I have a jl audio 1000/1 v1 amp pushing 2 15"
add more batteries to the truck and up grade the alternator and fuse
Jun 06, 2013 | Car Audio & Video
Jl 1000/1 goes into protective mode with low frequency
Do you have a capacitor????? If not, when its up loud and hitting hard it might be going into protection because of a voltage sag....If it goes below 11.8v they will usually do that.....Get a multi meter and put on the hot and ground of your amp when its playing loud and see what the voltage is dropping to.....If its going below 12v, thats your luck....
May 02, 2012 | Jl Audio 1000/1 Car Audio Amplifier
Sleuthing a 300/4 low-ohm issue. 300/4 amp history: unknown. just connected today whole system yesterday/today: head unit, 300/4(to 4 polk 6.5" component speakers brand new) 1000/1 (4-W3's),...
Are you sure you getting enough power to push everything. I have seen when the voltage is too low coming in, the amps will shut down so they don't overheat. Once they've cooled off and the volume level is lowered they will kick in again. Low voltage and a heavy draw will create massive amounts of heat.
May 24, 2011 | Jl Audio 500/1 Car Audio Amplifier
I have a 1000/1 amp running two W6s in my truck along with a 300/ going strictly to my highs, i also have a capacitor for 1000 that only runs for the 1000/ amp and a JL audio 100 amp fuse for all of it....
You need to get another capacitor and wire it in series with the fist cap when you crank the volume your system is not getting enough power from the alternator this is called surge current. In modern electrical systems we use capacitors to compensate for these surges.
Mar 05, 2011 | Jl Audio 1000/1 Car Audio Amplifier
When i turn the volume up my jl 1000/1 amp turns off then turns back on when the volume is low what can i do to fix this?
2 things, either your pushing too much power into the imputs (if using high inputs) and clipping the signal, or your running the ohms too low (lower then the amp can handle safely) by running multiple speakers of too low an ohm each. For example if your amp is 4 ohm stable and your running 2 4 ohm speakers in parallel that makes 2ohms and the amp can't handle a load that low. You can consult your manual and it will give you illistrations of wiring and ohm loads
Oct 26, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl 1000/1 cuts out
Hello, It sounds like you may have a problem with one of your subs. If this problem was not happening before that's what I would suspect. You need to check the ohms of both subs seperately, make sure you don't have a half blown sub. Second you need to test the voltage going into the amp while playing at a decent volume to see if there is a major drop in voltage. Also, check your ground. You'd be surprised at the many people who bring there cars to my shop with similar problems and turns out the ground was bad or loose. I would doubt there is something wrong internaly with your amp. The problem lies in the wiring or speakers. As you said it only started doing this after 3 or 4 months after it was installed. It's cutting off at high volumes cause it can't draw the power it needs at the higher volume, so make sure you check all your wiring good. Let me know what you find, I would like to be able to help you more if for some reason you can't figure it out. I own a shop and also do amplifire repair. Hope this helps.
Aug 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Alpine pdx 1.000 keeps cutting out
You are going to want to make sure all your power wires and grounds are 4 gauge as well as the wire leads to and from the capacitor-4 gauge also. make sure you have a very good ground - the power wire from the battery should hit a distribution block-from the dist. block a 4 gauge should go to the capacitor another 4 gauge to the mono amp and another to the 4 channel amp -every component should have a good solid ground even if you have to bust out a grinder and a drill and some self tapping sheet metal screws and go nuts on it- see if that helps you
May 26, 2009 | Alpine PDX-1.600 Car Audio Amplifier
My amp cuts off when i turn it up
do you have the amp knobs cranked?? gain and freq
May 05, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Power issue
Hello highs31 Ok this is a common problem and the fix is quite easy. even though you may not want to hear it. Here it goes: Your amplifier is drawing more current then your alternator can put out and more then your voltage regulator can control. This means that you must and I repeat must add another battery, alternator, and voltage regulator for your sound system. adding these components will eliminate your problems. That is the long and the short of it. I hope this helps, Thank you, Shuttle83
Oct 09, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 1000/1 Car Audio Amplifier Logo
348 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
