Question about Dell Audio Players & Recorders
Background noise recording with dell
When I use Dell Media Centre to record my singing lessons there is way too much background noise and its not coming from the room. It doesn't sound like static to me. I noticed the same kind of white noise on the Youtube video I used to learn about Media Centre - you could hardly hear the guy. There is no problem with the sound with skype or when playing audio files - just with my own live recordings. I have a Dell inspiron laptop with windows 7 & no external speakers. Any suggestions would be appreciated.
    Master:
  • 347 Answers
Get a wired lapel microphone and plug it into the microphone input on your Dell. The onboard mic is designed to record all ambient sounds. You want a different product to get the result you're looking for.
Posted on May 20, 2017
Open SKy
  • 620 Answers
SOURCE: Logitech x-530 speakers connected to Highlander DVD recorder
YOu need to install the right drivers, for your sound and video card, latest. and Direct X9c.
Posted on Jan 14, 2008
rtrahan
  • 741 Answers
SOURCE: Quiet Noisey feedback out of speakers
The speakers are not hooked up correctly. I don't know if you still have the instructions but it is a hardware problem and not software. Try to figure out how to hook them up correctly.
Posted on Dec 27, 2008
sys_admin
  • 829 Answers
SOURCE: static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Posted on Jan 01, 2009
yooperbud
  • 8637 Answers
SOURCE: Recorded Video Plays back static
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Posted on Feb 04, 2009
  • 89 Answers
SOURCE: Whenever I played a video
try going to your sound settings and lowering the input sensitivity that buzzing your hearing might be cause by the mic input volume is to loud
Posted on Aug 01, 2009
Why is it suddenly way too quiet?
Try a different mic to see if problem follows. If yes then it is a setting. If not then the mic is bad and needs to be sent to mfg or get a new one.
Dec 18, 2015 | Samson C01U - USB Studio Condenser...
Back ground noise
You cannot remove the background noise of already recorded material unless you have special software for that purpose. It is available, but costly. To eliminate some background noise, you may in the future, try to muffle the microphone by turning down the volume and recording by moving the device closer to the sound sources. Some folks put a wind sock over the recorder, as you may have noticed during TV News recordings on street events or at a studio. Try a wool or thick sock over the recorder and see if that helps.
Apr 15, 2014 | Olympus VN-711PC Digital Voice Recorder...
I Purchased behringer c1 u microphone and I want to record my singing with karoke..Problem is that when I connect laptop with speakers my singing volume is coming louder but sound of background music is...
You need a mixer. Connect the microphone to the mixer and also the background music. That way you have separate control of volume for the voice and the music.
The background noise can come from different sources. One of them is from the laptop itself, if the laptop is noisy to begin with.
Mar 14, 2014 | Behringer C1U Microphone
Playback background noise
Undo the previous recording after each take
Dec 23, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I have the hp inspiron 531s.Can i burn cd or dvd??
Yes your computer has a DVD writer... It should have the software to burn DVDs and CDs
The Dell Inspiron 531 is a desktop personal computer with a Microsoft Windows operating system. An Inspiron equipped with a CD burner can be used to record audio discs using Windows Media Player, which comes installed on the Inspiron as a standard part of the software package Dell loads onto its computers. Blank, recordable discs and pre-recorded audio CDs are the only supplies needed for the project.
Read more: How to Burn Audio CDs With Dell Inspiron 531 ' eHow.com http://www.ehow.com/how_6210098_burn-cds-dell-inspiron-531.html#ixzz1XyrRh8L7
Sep 15, 2011 | Dell Inspiron 531s Desktop Computer
Dell Jukebox is stuck in Rescue Mode
did any of this stuff actualy work?? because i am having the same problem with mine the only thing is as long as i've had mine i didn't even know where the reset button was.
Mar 23, 2009 | Dell DJ MP3 Player
Dec 27, 2008 | Dell Inspiron 1521 Laptop
What do the button symbols mean on my Dell TV/ monitor remote control?
It would help if you could provide pictures of the buttons in question. There should be documentation on Dell's website for you to download for free... unless you can find the user's manual.
Feb 17, 2008 | Computers & Internet
32 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
