Question about Bosch WFE 2021 Front Load All-in-One Washer / Dryer
Fault code 01
Can anybody help ? Bosch WFE 2021 washing machine starts cycle then stops with remining timer changing to 01.
  • Anonymous Jan 17, 2008
    I have exactly the same problem with Bosch Exxcel 1200 so would appreciate similar advice!
This is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Posted on Jan 18, 2008
SOURCE:
Hello! How can I get the instructions manual for
You're in luck -
http://www.bosch-home.co.uk/
click on "download product manuals"
click on "click here to download product manuals" - this will open a new tab or window.
Enter WFE2021EE/01 and click on Go.
results are in spanish, but I expect you'll be ok with that.
Aug 03, 2009 | Bosch WFE 2021 Front Load All-in-One...
Bosch WFE 2021
I suggest that you check the brushes in the motor for wear.
Remove rear panel, remove drive belt, undo bolts securing motor, unplug motor lead and earth wire.
Lever motor back, keeping hold of it, and remove.
Check the brushes, they are at the opp end to the motor pulley, if there is less than 8mm left, then replace brushes.
I would also check the pump filter, and clean if req'd.
Please rate my fixya solution.
Thanks.
Feb 08, 2009 | Bosch WFE 2021 Front Load All-in-One...
Flickering display panel Boschwfe 2021
It may be the door interlock that is faulty. This is the cheaper solution however it maybe the the electonic board. In any case it needs the attention of a bosch Technician. Cross your fingers its the door interlock.
0417362396 Melbourne metro Area
Regards Sam
Jan 05, 2009 | Bosch WFE 2021 Front Load All-in-One...
Bosch Washing Machine WFE 2021
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the blockage is in your plumbing and not in the machine.
Jul 29, 2008 | Bosch WFE 2021 Front Load All-in-One...
Bosch WFE 2021 machine does not complete wash...
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Jan 04, 2008 | Bosch WFE 2021 Front Load All-in-One...
Bosch wfk2201 washing machine
Contact Bosch through their web site. They offer solutions to some problems if yours is no listed send them an email.
Jan 01, 2008 | Bosch WFE 2021 Front Load All-in-One...
BOSCH washing Machine WFE 2021
perhaps it is waiting for user to add fabric softener? how it got in this mode?
May 28, 2007 | Bosch WFE 2021 Front Load All-in-One...
Bosch WFE 2021 Front Load All-in-One Washer / Dryer Logo
1,094 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
