Question about 2wire HomePortal 1800HG Router (1000400229000)
Setting up the wriless network
I have done everything the manual has told me to do, I have connected the gateway to my computer via an Ethernet cable and the network is now connected. However, it tells me to plug my broadband cable into the gateway and then connect to http://gateway.2wire.net/setup from my browser. The problem is that I am no longer connected to the internet as the broadband wire is plugged into the gateway i'm trying to set up, and not into my modem. What do i do?
    Guru:
  • 120 Answers
You need to have a cable going from the modem to the gateway, and then another wire going from the gateway to the computer.
Posted on Oct 04, 2007
Samsung BD 6300 blue ray player does not connect to wireless access point. Gateway ping seems to be the issue, current gateway is on the network. Using my landlords router with his permission. Suggestions...
I'm not sure if I'm reading this right but, Is the Access Point in your apt? Or are you trying to access his router directly with your 'Player?
If you are trying to connect to an actual Access Point, try connecting to the AP from your computer either wireless or via the Ethernet cable and set it up to access his router/internet. When you can surf the Web or access his network on the computer using the AP then unplug the cable if you used it and just go into the Samsung's network settings and try again.
The only other thing I can think of is make sure his router is set to MIX, b/g/n speeds.
Jan 04, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Bigpond have sent me my 4 port Wi-Fi modem thompson TG782T Home Network Gateway, now I am sitting here trying to figure out just where everything goes!!! I received a cd rom however I can't get it to work,...
Telephone wall-plate <---- 4-strand telephone-cord ---> telephone-port in modem
AC power from wall-plate to modem.
LAN port #1 <--- Ethernet cable --> network-port on desktop/laptop computer #1.
LAN port #2 <--- Ethernet cable --> network-port on desktop/laptop computer #2.
LAN port #3 <--- Ethernet cable --> network-port on desktop/laptop computer #3.
LAN port #4 <--- Ethernet cable --> network-port on desktop/laptop computer #4.
Configure the router's wireless adapter:
* set a SSID
* set an encryption-level, e.g., 'WPA'
* set a network password
Use the SSID/password to configure your wireless devices (iPod Touch, iPad, XBOX 360, etc.)
Nov 26, 2010 | Gateway Computers & Internet
Not showing the network ip address. Note i changed it from 192... to 172... and now trying to go back to the 192.168... network
Set the camera to "automatically obtain an IP-address".
Connect the camera, via an Ethernet network cable, to a router.
The router will supply a valid IP-address to the camera; much simpler than trying to "manually" set an IP-address, network-mask, and gateway IP-address.
Dec 08, 2009 | Veo Observer Network Camera
Can't connect DSi with same security as comps
hello, yes i had the same problem, but i had it with many other computers, the way i solved it was going into the router settings and click the "restore default settings" then turned the router off for 15 seconds (for a fresh reboot) then when i had to set everything up again i got all my computers on the router and im able to add more without running into that same problem once again, or for a simpler solution try disconnecting the wireless on the computers and replugging them in.... that works sometimes as well
May 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Lost connectivity to network printer when switched to ATT u-Verse
Is the printer connected via wireless? When I recently connected up a new wireless printer to my UVerse network, the printer manual said that establishing the first connection works better via an Ethernet cable directly to the Uverse router. After the printer is set up once, then I could remove the ethernet cable and connect to the printer via wireless from all my computers.
For all wireless PCs that were previously connected via wireless to dsl, you need to create a new network connection for each one, then enter the key that is listed on the side of your Uverse router when prompted. Sometimes it takes a few minutes to establish the connection.
I am amazed that ATT was so unhelpful on these issues. I was one of their first Uverse customers in Texas, and several times over the last years, techs would visit my house to solve a problem or hook something up, explaining to me as he went. That their helpful attitude is deteriorating is a real shame.
Mar 11, 2009 | Computers & Internet
Switching from Linksys 5 port switch to Netgear 8 Port Gigabit
Kindly check the Gateway used in the computer where internet is working.....
to find gateway follow this
start menu >>> RUN>> CMD>>>> Ipconfig
then configure this gateway in all other systems and ask for DNS from you isp as well..to provide DNS manulay.
If still dont work ...
tell me the all information you get by useing ipconfig command in the PC where internet is working.
like IP address
Gateway
DNS
i will make you a map to follow.
best regards,
Dec 02, 2008 | NetGear ProSafe GS108 8-Port Gigabit...
Netgear 624
to set upa network
http://lifehacker.com/software/wifi/geek-to-live-set-up-a-home-wireless-network-162754.php
there is no "earthnet" connection. it is an ethernet connection. it looks like a phone cable but has larger ends than a phone connector. the router is connected to the computer via an ethernet cable if it needs to be hardwired to a ethernet port or internal ethernet card. a wireless connection only needs to be an add-on internal card w/antenna or a usb connector hub (it looks like a usb flash memory stick)
here is how it's done. netgear has the same type setup.
Oct 13, 2008 | NetGear WGT624 Wireless Router
Belkin N Modem Router If main PC which is ethernet wired to the modem router is swtiched off, laptops cannot access the internet. Does this mean that the PC to which the modem router is connected has to...
it will as long as the modem/router is connected to a phone line, instead of the pc, the only cable connected to the pc should be a ethernet cable; or you have the pc networking set that it connects via another pc instead of through a gateway, re run the wireless network wizard.
Sep 05, 2008 | Belkin Computers & Internet
Maxtor 500g network drive
Describe to me exactly how you are set-up. Include the IP addresses of each device and exactly what ports are being used on each device. Could like an IP mistake or in some cases an X-over cable is still required IF your switch does not have does not have a x-o button on it. But that depends how things are connected. These are the 2 most likely but need the above info to diagnose.
Jeff
Feb 15, 2008 | Computers & Internet
No default gateway !
This usually means that your network is connected but your computer can't obtain an IP address or default gateway from the ISP (Internet Service Provider) or router. Without an IP address, your computer cannot communicate on the network.
Jan 13, 2008 | Computers & Internet
Computers & Internet Logo
216 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
