Question about Kitchen Ranges
Clock,timer and oven does not work on Kenmore gas Range
The clock,timer and oven does not work on our Kenmore gas range. The oven light works and the electrical ignition on the top burners operates normally. We noticed this after an electrical storm was in the area. We did not notice a near lightning strike and this is the only problem in the house.
  • chuch2007 Oct 05, 2007
    The Model number is 362.72201890 on this Kenmore Gas Range.
    Thanks
  • 447 Answers
Let me know the model# and ill see if there are any thermal fuses. If not than most likely you will have to replace the EOC (Electronic oven control). Available at www3.sears.com
Posted on Oct 05, 2007
  • joey  shearer
    joey shearer Oct 05, 2007
    No fuses in your model -- the Eoc part number is WB11K0044 the overlay you need is white WB11K10002 black WB11K10003 almond WB11K10004
Oven and digital display clock and timer doesnt work but burners and oven light works
Clock & Main control display issues - YouTube
? 4:44
https://www.youtube.com/watch?v=OmOocInxHOo
Jun 28, 2013 - Uploaded by ApplianceVideo.com
... symptoms: Clock and display does not work At: http://www.appliancevideo.com For ... and show you how to ...
Range/Stove/Oven Repair - Replacing the Clock Timer ...
? 3:42
https://www.youtube.com/watch?v=0RSnf4wfSZM
Oct 20, 2011 - Uploaded by PartSelect
Range/Stove/Oven Repair - Replacing the Clock Timer (Frigidaire Part .... My timer still works fine, but ...
Y0315570 Amana Range/Stove/Oven - Appliance Timer
Dec 01, 2015 | Kitchen Ranges
Kenmore gas range model # 970-331513 oven will not light, no such model number on their webpage. The burners light but not the oven. The igniter glows, there is no smell of gas. Range is new to us. Also,...
I cannot find the model number either, however, if you look on the enclosure into which the control board fits, there will be a label with a number beginning with 316 or 318. If you provide me with that number I will try to help you. I am familiar with these as I work for a company that repairs failed timers.
Mar 30, 2011 | Kenmore 71071 Gas Kitchen Range
We were given an electric smooth top kenmore range. When it was initially plugged in, the digital panel came on. When the stove was pushed into place, the digital clock/timer went off and the oven won't...
The electronic timer/clock must be working and be in manual mode for the oven to work. Try turning the power off and on and see if it resets. If is doesn't you might need a new timer unit. If you don't need the timer and clock it can be easily by-passed at the rear by joining the active and load wires and the oven will work.
Feb 26, 2011 | Kenmore 9535 Electric Range
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Kenmore gas range, burners are working fine. Stove is not working, front panel, clock/timer..panel is off...
Hello there:
Please read the entire solution i have provided it doe4s cover things that you have said has already been checked but there is more to it
It won't bake or broil If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note... If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these, call a qualified appliance repair technician. The clock stopped The non-electronic clocks on gas range/ovens often don't last long. That's a problem, because the clock is essential to the self-cleaning and timed-bake features. Clocks are rarely repairable--you usually just have to replace them. Electronic clocks have been more reliable. But, they're often integrated with several other features of the range/oven. So when the clock develops a defect, it often renders the entire oven and broiler inoperative. The electronic clock is usually integrated with a circuit board, and the touchpad that holds the buttons you press is often a separate component. If your electronic clock is defective, you may need to replace the touchpad, circuit board, or both. Although these may be expensive, they aren't usually very complicated to replace.
Sep 28, 2010 | Kenmore 78733 Gas Kitchen Range
Clock and lights work but cook top and oven do
The clock and the lights run off of 120 volts and the heating elements work off of 240 volts.
It would be safe to say that one leg of the power is missing. Try turning the circuit breaker off then back on fully.
If this does not solve the problem then you will need an electrician to check the plug behind the range or the 'L2' in the range.
Apr 26, 2010 | Bosch HGS435UC Gas Kitchen Range
I have an amana gas stove model ARG7800WW . The cook top works but the display (Clock Timer) doesn't light up and the oven doesn't work.
u need a new clock , or the oven wont work , u can bypass the clock to get the oven going but u need to know which two wire to join
Oct 27, 2009 | Amana ARGS7650SS Gas Kitchen Range
Manual needed for Range operation: Specifically timer reset
I found the work-around to be to decrement the timer to 0 as a means of canceling it, "unset it" if you will.
Dec 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Oct 04, 2007 | Kitchen Ranges
Kitchen Ranges Logo
415 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
