Question about E-Machines eMachines Desktop PC
Computer won't boot
When I try to boot the computer, the fan comes on, the harddrive turns on but the monitor does not come on. I've tried putting in a video card and it didn't work that way either. The hard drive is ok because I have tested it as a slave on another computer and it has all the data on it. Any suggestions?
  • 2 more comments
  • Bkstroud Oct 04, 2007
    This is an eMachine W2260
  • Bkstroud Oct 05, 2007
    did that too.. figured out, its the motherboard. I learned if you uninstall the memory your supposed to hear 3 beeps when turned on .. *no beeps*
    tried that too. thanks... It's the motherboard. I learned that if you uninstall the memory, you should hear 3 beeps when you turn it on....*No beeps*
  • Anonymous Feb 10, 2008
    i need help
    Problem Solver:
  • 8 Answers
Set the jumper of the mother board.
set the jumper of the harddisk make it slave.
format the harddish and install fresh OS.
if not solve then update the bios.
Posted on Nov 17, 2007
  • 883 Answers
Ok, try another monitor now.
Posted on Oct 05, 2007
Ms 7145
william ,are the monitor okey,you maybe should try with a other.
did it came with a Os or.
Jul 17, 2013 | Computers & Internet
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
( Dell xps m1530 laptop ) Monitor blank, powers up but screen won't come on.
It ISN'T the LCD screen. Since you diagnosed with an external VGA monitor, you now know the problem is the laptop.
(When you connect an external VGA monitor to a laptop, you are bypassing the Video Cable, and LCD screen. You are connected directly to the laptop )
The basic Windows files aren't being found. The boot files. This may mean a bad Harddrive.
Do you have the Restoration CD Disk? Laptop on insert it into the optical drive tray, close the tray.
When asked choose - Repair. (Non-Destructive Installation)
If a checkdisk is done, you have bad sectors on the harddrive.
There IS a special procedure in replacing a harddrive.
[ More information on Harddrives,
http://computer.howstuffworks.com/hard-disk.htm ]
Regards,
joecoolvette
Feb 26, 2012 | Dell XPS M1530 Laptop
My computer won't turn on, it just has a blinking dash on the left hand side I've tried turning it off and on multiple times and nothing will work I have an assigment due at the end of this week...
while the computer is turning on push the escape key and try selecting the harddrive
if it doesn't start to boot into windows then your boot record is probably corrupt you can try fixing it by running chkdsk /r on your OEM reinstall disc that came with the computer, seeing as you have a netbook you will need a external cd rom
Jun 14, 2011 | ASUS Netbook
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
P4M800 Wont boot
Hello there:
please try this first unplug the power to the computer
next open the case and unplug all of the cables and cords that connect to the harddrive cd rom ect ect
now locate the power supply cord that goes to the motherboard and disconnect
press the power button on the computer for 20 seconds and also if you have a reset button press it . what this hoes is releases any stored esd that is in the computer ..
now plug in the power supply back into the board and plug in the power cord and try to boot the computer and see if it comes on if so great just plug in the cords to the cd rom harddrive ect ect and than reboot and you should be ok
Sep 23, 2009 | Biostar P4M800-M7A Motherboard
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Computer will not boot up at all
Emachines have had a lot of problems with their power supplies going bad and destroying the motherboard in the process. If you can, start looking for a replacement motherboard (on eBay) and a larger wattage power supply (any local computer store) especially if you have experienced the computer shutting off or rebooting for no apparent reason. If you're lucky, you can try booting into safe mode by pressing the "F8" key on you keyboard during the boot process and select safe mode from the menu. If your computer boots up, then there exist the possibility of a corrupt video driver and/or corrupted file system. If you still can't boot and experience the same thing, then you may have a physical hdd problem or again, power supply, motherboard, or both. Also, do not over look the possibility of an internal fan on the video chip not turning. I hope this helps and good luck.
Jun 10, 2007 | E-Machines eMachines W2686 PC Desktop
Computer powers off while booting, green light stays on!
1. check the cpu fan is properly working with normal speed..
2. go to bios setup and restore all settings to default.
3. if windows start and problem comes after some time , then it might be virus. so, go for a virus scan.
Oct 23, 2006 | Asrock K7VT4A+ Motherboard
E-Machines eMachines Desktop PC Logo
101 people viewed this question
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
