Question about Canon LaserBase MF5650 All-In-One Printer
Canon mf5650 mesage REC: paper jam open front cover. so i open the cover but there is no paper jammed i check the paper casset on jam. i have replaced the toner because it said the toner was low now it wont print at all thank god for my old HP still works no problem with it at at all.
  • 4 more comments
  • Anonymous Nov 24, 2007
    yes have a same problem,i did checked all required paper settings in software as well in printer it is A4.
    i have already opened printer & checked from inside also,but there is no paper jam.
    i have also restrated printer & pc as well,i have tried all sort of things but the error rec paper jam is not going.i am only able to scan from printer,i am not able to take print & copy.
    please guide me & probably give me more solutions possibly
  • Anonymous Jul 04, 2008
    I have the same problem. There is a document in memory and I can not reset. It only print this document.
  • workphdogoma Apr 15, 2009
  • Anonymous Mar 17, 2014
    paper jam after replacing the toner cartridge
    paper jams after replacing the toner cartridge
  • Anonymous Mar 23, 2014
    tried to print envelope and jammed.
    there's no jam
Check the paper setting in your software. Paper size should be A4 in all instances. Hope it helps
Posted on Oct 05, 2007
Rec. paper jam open right cover
Obviously you have a paper jam somewhere. Probably one the right side, open all the covers and pull the paper out.
Oct 20, 2013 | Canon FAX-L400 All-In-One Laser Printer
MF5500 Paper Jams Everywhere
check the paper ,from cassete tray to the drum and exit,on every section you have a sensor,check it ,
Feb 29, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
HL2040 paper light blinking
Open the paper cassete and check if you have load paper in it.The second thing you can do is to open your printer front cover, remove the drum unit and check for paper jam inside the printer.
Oct 21, 2010 | Brother HL-2040 Laser Printer
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image...
The paper jam could be in three places.
First:
Open the cover of fixing section, its above bypass, and check for jamed paper
Second:
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
Third:
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Jul 07, 2010 | Canon ImageRunner 1600 Copier
I am getting rec.paper jam no paper jammed though
Open back door, clean feed roller very well, and open and close upper cover.
May 28, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Paper jam /Message says Rec. Paper jam Open right cover
From right side of fax, open the toner door, remove the crg.unit, and look for paper, if not also from left side open the door and check for paper or broken parts in fixing unit.
May 21, 2009 | Canon FAX-L400 All-In-One Laser Printer
Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
PAPER JAM
laser printers dont use ink.
you will have to check the sensors. first the one where you put the media (paper) then check the registry one (remove the cartridge and you should see it) then the fixing on, from the back it has a small cover you can open an dthen a pair of green coloured levers to remove any jammed paper in fixing (the hot ***'y) then check the delivery sensor right where normally you see the page printed out and coming your way. there should not be any media remains anywhere. also if you copier is dirty it may also be causing this. try to clean it with compressed air.
Oct 29, 2008 | Canon imageCLASS D320 Digital Copier
Cannot find paper jam ...
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
Oct 21, 2008 | Canon ImageClass D880 Copier
Jarry cannon
open printer cover, pull out toner cartridge, re-install cartridge, close door, it should re-boot the machine.
Mar 14, 2008 | Canon LaserBase MF5750 All-In-One Printer
Canon LaserBase MF5650 All-In-One Printer Logo
460 people viewed this question
Clive
Clive
old marine
old marine
