Question about Saeco Vienna Espresso Machine
Steamer does not work
When the steamer is turned on, no steam comes out. There is a rhythmic steaming clicking sound with the machine. Thanks...Khanh
  • Anonymous Jan 06, 2008
    no steam comes out of the steamer, although hot water comes out when it's first turned on. i don't think it's clogged, but tried cleaning it out with a paper clip anyway. no improvement.
    Sergeant:
  • Saeco Expert
  • 223 Answers
Your steam wand is probably clogged with milk. Remove the panarello outside and stick a paper clip up the tube. Then try to run water out of the steam wand.
Hope this helps!
johnny
Posted on Oct 12, 2007
How to make steam come out
Did you consult the user manual on this?
Oct 07, 2016 | Oreck Steam-It All-Purpose Steam Wand
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
Can not turn on the steam mop
I was able to turn on the steam mop, but no matter how hard I pumped the handle... no steam. Someone here said to put vinegar into the water bottle. I realized that they were saying particles from the water could have formed and clogged the steam tube. First, make sure your steamer is OFF!! Turn the steamer upside down as though you were putting a new pad on, Use a slender object to clean out the tubing where the steam comes from. Again, I will say... make sure your machine is off before you attempt this.. Otherwise, when you clean out the tubing the object will become a bullet flying thru the air and can hurt you, Hope this works
Dec 01, 2014 | Bissell 39W7 Lift-Off Hand Steamer and...
The steamer dosen't work at all. When the knob is
First you should remove the end tip of the steam hose and try to clean the steam holes with a pin. The steam should come frealy withou the end tip. If not then you shoul desasemble the steam tap , clean it and put it back together. The problem is only caused by dry milk or milk with chocolate. Even if you manage to have some steam then the problem can be solve by using the steamer warming just water in a glass and leave it all nigh long inside the boiling water in glass this will meld the dirt and will gos away.
Feb 09, 2010 | Rancilio S24 Espresso Machine
Steamer
Take off the edge on the steam pipe, clean it and mount it again.
/Mirran
Aug 31, 2008 | Breville ESP8XL Espresso Machine
No steam in scunci steamer will not work lights uop hear pressure and heats up
no steam in scunci steamer, it does gets warm but no steam at all. like if it was blocked
Aug 29, 2008 | Scunci 52001 Handheld Steam Vacuum
Steamer on gaggia titanium
a. Possible air in the system. Switch to hot water iso steam, let warm water pas for a minute by turning the knob fully open. Stop tapping warm water (close the knob) and switch the machine to steam iso water. Try to get the steam by fully opening the knob (pump should start running).
b. Solidified milk in the system blocking internal tubes. To avoid this always purge the system (shortly open the steam to an empty cup or a towel) after you steamed milk to avoid milk being sucked back into the system due to condensation of steam (this creates a vacuum and reverse flow). To resolve the blocked tubing: clean the nozzle and try flushing the system (tapping warm water).
Aug 24, 2008 | Gaggia Titanium Espresso Machine
Steamer
Both tubes must be in the water. If you haven't used the machine for awhile, fill the water canister, turn the espresso maker on and also turn on the delivery switch (the top switch on the EC140). You'll hear the pump and in a second or two water will begin to exit the boiler nozzle. Immediately turn the delivery switch off. Wait for the "OK" light to come on. Press the "Steam" switch (the middle switch on the EC140, place an empty cup under the frother and turn the steam control knob on top in the counterclockwise direction. Steam will come from the frother. Be very careful to avoid contact with this steam.
Apr 23, 2008 | DeLonghi EC140 Espresso Machine
Milk frother /steamer not working
if you could remove the pipe put the pipe in a solution to remove the calcium in thr pipe dry calcium is like concrete dip it and use a piece of wire to clean cheers
Jan 18, 2008 | Solis Crema SL-70 Espresso Machine
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Saeco Vienna Espresso Machine Logo
308 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
