Washer spins, but doesn't spin the water out. already replaced pump & belt. also, even though level, spins out of balance during start-up of spin cycles. before spending more money for parts that aren't the problem, would like to know if i'm even "hot" in the resolution. Motor coupler or transmission? Or something else?
SOURCE: damp and piled up clothes at the end of each cycle
Good Day.... I feel for you... Unknowingly,When they purchase it. Many people have the same experience in finding service for products such as your experiencing.
Of course, it's our hope and belief, it's not ever going to have a problem, some people are lucky. Me neither... mine is in computers... but that's another story.. Just believe me, I understand ... but I'm going to try to help... why I picked up this call, is because I find it to be interesting, about the comment about the clothes gathering into a ball... Generally, that happens in relationship to the amount of water, inside or lack of it. If the clothes are in a ball, that's why they're coming out wet. Nobody makes a washer that can do that.
I want you to check the drain line...(that's the hose to water uses to exit) Is the hose at any point, higher than the top of the machine (it's supposed to be) ... if not siphoning may be occurring.
Also check to drain hose at the inlet, where the hose goes into the wall.. it must allow air to get in here as well. I have experienced some indifferent situations before, if the hose in stuffed into the stand-pipe, or taped,glued, sealed.. if there is no vacuum break (meaning-place in which air can enter) that to can create a siphon. Ge was known for having a washer that made the kind of bang you describe. It was their normal method for stopping the clothes basket from spinning forever. I hope this answer works for you, otherwise resolving may continue to be difficult. One piece of information you'll have received, is what you will and won't recommend to buy when you hear others having conversation on buying a major Appliance. Sometimes it's all we can do... I wish you best... dean
SOURCE: I just purchased a Haier
Put mine under the countertop where my dishwasher used to be. It shook around really bad in there, so I wedged a towel between top and counter, and also one on each side. That was enough to anchor it and it runs smooth and quiet. I am looking for something like a bean bag to free up my towels.
SOURCE: Haier Top Load Washer doesn't spin
Hi
There can be two possibilities,one if it has a belt, it is either stretched or slipping or if it doesnt have a belt then there is a clutch like device between the motor and the basket, which is either broke or cracked.
Or follow this easy steps...
Unplug the washer and turn off the water faucets.
Disconnect the water hoses and the drain hose and pull the washer away from the wall, leaving yourself enough room to work behind the appliance.
Lay an old towel down to kneel on and soak up any water that leaks from the hoses.
Remove the rear access panel.
Locate the motor. The rubber drive belt goes around a pulley wheel attached to the motor.
Press on the belt. If it gives more than ¾ inch or so, it needs to be tightened.
Loosen the mounting nut for the motor and push the entire motor to increase the tension on the belt.
Hold the motor in place and tighten the mounting nut.
Make sure you don't tighten the belt too much or it will break. You should be able to press on it and feel it give just slightly.
Replace the drive belt if it shows signs of wear.
Thanks for contacting fixya.com
Testimonial: "Thanks! I guess you're right. The belt seems to be too loose and shows signs of wearing. Already ordered new one. Thanks again!"
SOURCE: haier XQB40-F water will not pump out
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
