I could not find the deluxe model but I did find the Stylus Pro3800...hope this helps, at least it will show you the head cleaning procedure. Please leave rating
Cleaning the print head of an Epson Stylus 4000 printer can help to improve print quality and resolve issues such as missing or clogged nozzles. One method of cleaning the print head is to flush an ammonia/alcohol solution through it. Here's a step-by-step guide on how to do this:
Turn off the printer and unplug it from the power source.
Prepare a cleaning solution by mixing equal parts of ammonia and water or isopropyl alcohol with water. It's important to avoid using high-concentration cleaning solutions as they may damage the printer's internal components.
Take a syringe or bulb syringe (usually can be purchased at a pharmacy) and fill it with the cleaning solution.
Remove any ink cartridges from the printer.
Locate the print head assembly. It is usually located behind the ink cartridges.
Gently insert the syringe or bulb syringe into the print head assembly and slowly squeeze the cleaning solution through it.
Use the syringe or bulb syringe to gently flush the cleaning solution through the nozzles until the solution comes out clean.
Allow the print head to dry for a few minutes before reinserting the ink cartridges and turning the printer back on.
Perform a test print to check if the cleaning improved the print quality.
Note that you may need to repeat this process several times to completely clear the clogged nozzles. Also, before performing any of the steps listed above, it is advisable to consult your printer user manual or contact Epson support for specific instructions regarding your printer model, as the location of the print head and the exact process may vary depending on the printer model.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles. If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive. It may be more cost effective to buy a later model and better printer than replace the print head.
Hi Good day!! Try to do a printer maintenance Cleaning a Clogged Print Head
1. Press the cleaning button located on the front of the printer. Hold it down for 3 seconds to begin the cleaning cycle.
2. Run a cleaning cycle using your Epson printer utilities program. In Windows, go to "Start," "Printers and Faxes," right-click on your printer and choose "Printing Preferences." Select the "Utility" or "Maintenance" tab, depending on your printer model, and click "Head Cleaning." When the head cleaning cycle is complete, run "Nozzle Check." Repeat the head cleaning and nozzle check one to three times.
3. To access the Epson printer utility in OS X, select the Epson Printer Utility icon in the Applications folder in Macintosh HD. If prompted, select your printer from the Printer List, then click "OK."
Clean the print head manually. Remove the ink cartridges from your printer according to the instructions in your owner's manual. Turn off your printer. Dip a cotton swab in isopropyl alcohol, ammonia or hot water and rub the swab against the print head. Let the printer sit overnight.
Remove the print head according to the instructions in your owner's manual. Soak the print head for at least an hour in a small dish of hot water or isopropyl alcohol.
Preventing Clogged Print Heads
1. Use your printer at least once a week. Regular use will keep dried ink from clogging your print heads. If you have a color inkjet printer, print full color pages in addition to black-and-white documents.
2. Turn your printer off when not in use. This will prevent warm ink from bleeding onto the print head. If you have to store your printer, remove the ink cartridges.
3. Use a cleaning kit regularly. A cleaning kit usually includes a tube of ammonia that you spray on the printer head to clean dry ink.
Use "spet" (tube only). Add flexible pipe (cut from oultet pipe of head cleaning mechanic). Connect to nozzle. Fill tube with cleaner. Move head to parking position. Do suction from outlet pipe of head cleaning. It's the safely way to clean print head manually.
Follow the steps below to clean the print head using the Head Cleaning utility.
Make sure that the printer is turned on and the ink out light is off.
Access the printer software.
Click the Maintenance tab, then click the HeadCleaning button.
Follow the on-screen instructions.
The power light flashes while the printer performs the cleaning cycle.
Never turn off the printer while the power light is flashing. Doing so may damage the printer.
When the power light stops flashing, load a few sheets of paper and click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one: http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
