Question about Bower (724AFM) for Minolta Maxxum, Dimage TTL Flash
Flash wont flash!
The flash turns on, I can hear the humming and the on as well as the ready light turns on, however when I hit the test button or attach to camera the flash does not flash, is the bulb burnt? Can I fix this at an affordable rate?
    Champion:
  • 225 Answers
First you check the inside flash circuit, any copanent may be burntout or drysolder, check properly, one mor inside the flasah capacitor very high voltage becarefully..
Posted on Oct 06, 2007
SOURCE:
2001 tp cruiser turn signals wont flash
check the flasher relays in the fuse box. these are what causes the lights to flash.
Feb 11, 2014 | Chrysler Cars & Trucks
Sigma EF-530 DG ST - not working, on test or camera all 6 LED lights displaying. Any thoughts?
I don’t usually play with flash that isn’t built in- I prefer natural light, but...if this were me I would: A) take very fine sandpaper and very lightly go one time over all contacts for the flash and camera. B) I would also see if my button batteries in my camera needed changing. As I remember they have something to do with recognizing lenses and flash attachments. C) I would also make sure the batteries in the flash, although changed, were making proper contact with the battery terminals and might also lightly sand those as well since the flash is little used.
Jan 10, 2018 | Sigma EF-530 DG ST for Pentax TTL Flash
SB-600 display shows, but will not fire or test fire
there's a part in inside that triggers the light .. it might need to be fixed.
Please contact Nikon Tech Support to walk you through resetting the flash.
a. Have you tried that? it's in the Manual
Sep 07, 2009 | Nikon Speedlight SB-600 TTL Flash
Metz 58 AF with Nikon d90 wont flash
Hi, Bad news for you.
Try this.
  1. put new batteries in flash.
  2. turn flash on off camera.
  3. listen for capacitor to squeal (high pitched whistle). If you hear it it is charging. If not capacitor is bad.
  4. Also should see flash ready light come on. If it does not same as #3 above.
  5. If you pass #3 & 4# above press manual flash/check/test button on flash. No flash means bulb is out. It can be replaced.
Hope this fixed ya. Please rate. Good Luck! Comment back if you need further assistance.
Mar 14, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Flash won't shoot
does the red bulb show when the flash is ready to shoot ? you can press the button that lights red or green to test the flash on itself.
Mar 10, 2009 | Canon Speedlite 550EX TTL Flash
Flash doesn't fire
Should fire from test button. If not flash tube is blown.
Jul 08, 2017 | Digital Concepts 952AF for Pentax Flash
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Bower (724AFM) for Minolta Maxxum, Dimage TTL Flash Logo
150 people viewed this question
Top Bower Cameras Experts
Doberman
Jerry Greenberg
Jerry Greenberg
photopest
Level 1 Expert
Are you a Bower Camera Expert? Answer questions, earn points and help others
