Question about Magic Chef CGS3760 Gas Kitchen Range
Magic chef stove
For no reason the stove starts beeping and f1 is displayed on the screen. the stove must be at least 10 years old
  • Anonymous Jul 07, 2008
    Stove beeps and F1 is on display. I don't know what to do.
  • Anonymous Jan 26, 2009
    got a second-hand magic chef stove -- it continuously beeps and shows "F1" on the screen. how do i get rid of this beeping?
Mine does it too. This error is probably caused by the computer overheating. It especially happens when I'm broiling at high heat. However, when I'm roasting it almost never happens.
I just hit 'cancel', reset the oven and start baking/broiling again. Repeat this until your food is done.
Posted on Sep 01, 2008
  • 447 Answers
F1 means the computer has corrupted....... Part is probably around $150-200 Please rate my help solved as I solved your question.
Posted on Oct 04, 2007
SOURCE:
Magic Chef gas stove periodically starts beeping and "F-1" appears in the display
Hi alflaw,
F1 error indicates a bad touch pad or clock (ERC). To fix this error code, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Feb 05, 2010 | Magic Chef 31000 Gas Kitchen Range
Our magic chef oven starts beeping and gives us a F1 on the display
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
Sep 13, 2009 | Magic Chef 9815 Electric Single Oven
Intermittent alarm
pull your range out there is a tech sheet on the back that will tell you what the reason for the f1 code is. you can go from there.
Jan 03, 2009 | Magic Chef Kitchen Ranges
F0 fault code on magic chef gas range
Do not recognize a F0 code only F1-F10. Recommend unplugging and replug.
Dec 09, 2008 | Magic Chef 31100 Gas Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Sep 18, 2008 | Kitchen Ranges
Tappen gas 4 burner about 10 years old with about 10 hrs total use time(basement stove)
Hi Carlsr,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Apr 13, 2008 | Tappan TGF320 Gas Kitchen Range
Magic chef range
f1 is the code for a failed clock most of the times you must replace the clock most of them have a five year warrenty check your owners manuel for warrenty info
Mar 12, 2008 | Cooktops
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
What is this F-! mean
Oven control beeps & displays any F  code error (for example F11) - Electronic control has detected a fault condition. Press CLEAR/OFF to clear the display & stop beeping. Reprogram oven. If fault recurs, record fault number. Press CLEAR/OFF & contact an authorized service agent.
Sep 03, 2007 | Magic Chef CER3725AA Electric Kitchen...
Magic Chef CGS3760 Gas Kitchen Range Logo
506 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Steve Allison
Steve Allison
John Tripp
John Tripp
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
