Question about Palm Tungsten T5 Handheld
Palm Tungsten t5 WiFi
I cannot get a WiFi connection on my Palm Tungsten T5. I have done a hard reset & re-installed the software several times but no luck. It always says "No networks found". That's as far as it goes. It used to work until I sent my Palm in for warranty repair, and they sent a replacement unit. I'm pretty sure that's when the problem started.
  • sugararrow Nov 21, 2007
    I just want to ask,if my T5 can have a wifi features
  • Anonymous Jan 25, 2008
    I had the same problem with the T5 and WiFi Card. I also believe the problem started after sending it in for warranty replacement. (But the unit has since packed it in completely, so I don't need a solution).
    Dave
  • 46 Answers
I suspect that you're in fact holding a Palm TX and not a T5 as the T5 does not have WiFi. If you're using the Palm SD WiFi adaptor, do a hard reset without the card.
(hold down the ON/OFF button whilst using the reset pin to press the reset button. You'll be asked if you are sure you wish to reset. You'll then be prompted to choose the language caliberate the screen etc..)
After that. Go and download all the updates and drivers from Palm Web site.
Posted on Nov 20, 2007
Trying to reset my t5 wont hard reset
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 24, 2010 | Palm Tungsten T5 Handheld
Palm tungsten t5 won't boot past the Palm Powered
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your T5, so only do it if you have to. Hold the Power Button while you push the reset button. Continue with the instructions to finish erasing your device.
Feb 17, 2010 | Palm Tungsten T5 Handheld
Upgraded from tungsten e to tungsten t5 did first hotsync but subsequently get error message line:4038 error launching application
Hello.
From Palm Support:
When you upgraded from the E to the T5, did you precisely follow the upgrade directions? These steps include the following actions:
Did you install the new Palm software that came with the T5? Did you rename the Backup folder on your computer before you synced the T5?
If you did not rename the Backup folder you have installed system and preferences files from the E that are not compatible with the T5 and NVFS.
Advise that you hard reset to return the E to factory condition and precisely follow the upgrade procedures.
Hope this helps.
Jan 05, 2010 | Palm Tungsten T5 Handheld
I have a palm tungsten t5 and need to link it to my new computer but I can not find the installation cd. Could you advise where I can download from? Thanks Steve
Here is a link to download everything you are looking for for your T5. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/t5/unlocked/home/page_en.html
Nov 13, 2009 | Palm Tungsten T5 Handheld
Palm T5 installation disk is damaged. HELP!
HI,
Here is the info you are looking for. There is a whole section of help topics on the palm website. This is the link to download the software.
Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/t5/unlocked/downloads/page_en.html
Oct 25, 2009 | Palm Tungsten T5 Handheld
How do you flash the rom on tungsten t5
Sir now you have to upgrade the software of your phone
Jun 01, 2009 | Palm Tungsten T5 Handheld
T5 is frozen on the "Palm Powered" screen
Remove the battery and let the palm sit for a day, reconnect the battery and do a hard reset. To remove the battery, you need a Torx T5 screwdriver. Carefully remove the cover making a note of the location of all the buttons in the case. The battery is connected by a mini 2 pin connector, just disconnect the battery by gently wiggling the connector and pulling.
Mar 06, 2009 | Palm Tungsten T5 - Multilingual Handheld
pls try these steps first
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=1156,E=0000000000310371479,K=2039,Sxi=10,case=obj(33016)
otherwise update rom from here
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(15356)
pls rate me fixya if i have fixed ur problem
Mar 03, 2009 | Palm Tungsten T5 Handheld
Tungsten T5 re-install on new computer
u have to re install the whole software on new laptop
just download the software from here and install
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=1821,E=0000000000310373016,K=2039,Sxi=12,t=downloads,Question=Ref(q_activetab):str(downloads)
Feb 16, 2009 | Palm Tungsten T5 Handheld
On/off switch
I am pretty sure this is a software problem, not a switch problem. The T5 is the Ford Edsel of the Palm range, with many unsolved bugs. I fixed this problem by using shortcut for ON and OFF.
Switch ON:
Use one of the 4 application buttons. The default house button opens the Palm at the menu, but you can change any of the buttons in
Preferences > Personal Buttons
to open whatever application is convenient.
Switch OFF
In
Preferences > Other Offstroke
check Enabled, and Pen Stroke or Screen Tap (or both), and then select the gesture that will turn off the Palm. I use "Screen Tap in top left corner" to turn off.
It's not a real solution, just a workaround. I also flushed and reset the T5 and reloaded from backup, and the problem went away for a while, then came back. It gradually takes longer and longer to switch on and off. There is some bug in the OS, but Palm doesn't seem to care about it.
Nov 13, 2007 | Palm Tungsten T5 Handheld
Open Questions:
Palm Tungsten T5 Handheld Logo
233 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
