Question about JVC AV-56P575 56" Rear Projection HDTV-Ready Television
BLUE tint instead of black
My picture looks great except when blacks are present which are replaced by a bluish tint. What happened and how can this be resolved? I can disassemble and solder just about anything so making the repairs myself wouldn't be an issue. THanks in advance for all your help. Mike
  • maitaka Oct 05, 2007
    Hey, thanks for the quick response.
    Would you explain what is the BLUE color control and how would I go about adjusting it? I don't think it's something that I can do through the menu since I've already looked for something like this.
    I can use the scope, multimeter and pattern generator to fine tune the picture, but it would be great if I knew how to adjust the blue color. THanks so much for your help.
    I'm wondering if there isn't sometype of cold solder joint or an electrical component or components that have gone bad since this set was working perfectly just a few days ago.
    Would you guys have any other suggestions apart from just a color adjustment?
    Thanks again for such quick responses.
  • 1,139 Answers
This is an indication that the blue gun is being driven too hard. Have you tried to adjust the blue color control? If not try this first and if the control can not adjust the color then you will have to find out if the control grid on the blue tube is working and has the proper voltages present. Which you will need the following equipment to do. Multimeter Oscilloscope Along with these you will need a schematic to show you what the signals and voltages should be. And I might also suggest having a pattern generator and using the color bar signal since more then likely that is the one being used in the schematic as the reference signal.
Posted on Oct 04, 2007
  • Henry McKelvey
    Henry McKelvey Oct 05, 2007
    There should be an adjustment inside the set which is basically a course adjustment for the intensity of the color Its location should be on the schematic around the area of the blue video amplifier.
Why i pictures in view finder always turn pink. Like a mouse pad is black on my desk when I take a picture of it, it comes out pink. My camera is a panasonic D
This would happen if the color balance was on the wrong setting. Check your user manual by looking for either color balance or white balance. You will want to return the setting to "automatic" or whatever the default is called. On many cameras it is easy to accidentally change this setting. It is used to reduce the yellow look of tungsten bulbs, the green of fluorescent, or the bluish tint of shadows.
Jun 02, 2014 | Cameras
KDF-E50A10 - hard to see details during dark scenes and a dark bluish tint can be seen in background. When tv is turned off the screen goes black but has bluish tint toward the edges before it all goes...
Hate to tell you this but it sounds like your picture module is going bad. The bluish tint tells me it is leaking to the outside. Some problems with the LCD picture module can be fixed but I never had to fix one. Might check out some videos on repairing LCD picture tubes on YouTube.
Dec 03, 2013 | Sony KDF-E50A10 50 in. LCD HDTV
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
May 20, 2013 | Home
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
Picture and menus are red-tinted all over
check system mode on dvd player,should be on pal
Jul 12, 2009 | Televison & Video
Bluish green tint to television picture
Find out what board and circuit is responsible for the color and you have your answer.
Mar 12, 2017 | Panasonic PT-52LCX66 Projection Television
Blue tint on rear projection tv
If this is a crts model , then one of the crts had blown, if it is a lamp rear projection, then it is a fault on the video circuit.
Mar 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Sony Wega 50" DLP bluish tint
the issue is the optical block. replace the optical block
Jan 07, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Background has a bluish tint instead of white
the lens , glass inside your scanner is dirty with dust you need to clean this up and calibrate once again cheers
Nov 26, 2008 | Canon CanoScan 9950F Flatbed Scanner
Lights come on but nothing shows its black.lens looks good
I have seen a few of this model and the tubes were gone in each case. Best way is to check if HV present at tube - get someone who knows what they are doing to take a look. If it is the tube, it will be expensive to repair. Unscrewing the lens may reveal that the inner surface of the tube has dark marks, also indicating possible tube damage.
Nov 13, 2008 | Famous Trails Calypso FT700 Monocular
JVC AV-56P575 56" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
