Dell A525 Computer Speakers Logo
A
Anonymous Posted on Nov 09, 2013
I found a a525 Zylux &or Dell and it never dawned on me Sound Card,I have none,But I was sureprised it powered up I cut a 9 pin old monitor plug and jury rigged the pairs.I know I gave a radios output to dells powered subwoofer red & black pair and the only way to get any sound/not get feedback no mattter which wires you have landed is Green & Yellow must be strapped togetyher,after that Sub works and purrple - & orange +pair will drive a spkr,Stay away from the Blue wire it has 12 VDC and it probabbly supplied the power for the slave speakers,Thers another wiring way where I go throughh the grn/yloww pair and get 2 outputs and one seems powered or something cause it is loud,So in effect I still have low end radio casste playesr other output toutilize
4 Related Answers
Anonymous
  • 10 Answers
  • Posted on Dec 12, 2009
SOURCE: Bought a set of logitech speakers - using with my
This means that your speakers have surround sound capability. The black one is for the REAR L-R sound, the orange one is for the CENTER sound, and the green is for the standard stereo FRONT L-R sound.
Your computer only has a green slot, so it means it does not support surround by default. You should simply insert the green speaker jack into the green slot on your laptop, and you should be good to go. The orange and black ones aren't necessary at all, so it's fine to ignore them for now.
Anonymous
  • 4102 Answers
  • Posted on Jan 25, 2010
SOURCE: how do I connect speakers wire 9 pin plug to 9 pin
hi, all you need to do is go to a computer hardware store and just ask them if you can buy a male to female converter these can be brought for next to nothing and this will then solve your problem.
Let me know how you get on or if you need further assistance ok
Anonymous
  • 569 Answers
  • Posted on Apr 01, 2010
SOURCE: Rear Speaker delay
It will not be the length of the wires, as the signal travels at close to the speed of light!
If the connections to the speakers are bare wires the cause is probably that you have wired the speakers with opposing polarity. Check the wiring and ensure that positive (red) is wired to positive on the speakers.
The speaker cable should be marked in some way to indicate which core is which. It doesn't matter which core you use provided that you wire red to red and black to black, or whatever other colours your output and input have.
petrillaa
petrillaa
  • 8 Answers
  • Posted on Feb 07, 2013
SOURCE: I have a Dell/Zylux A425 2.1 audio system for a
It seem your amplifier doesn't work, nothing to do with your computer, you can check with any other source lik eMP3 player, etc. If you take apart the box, there are some SJ4558 dual opamp. In my panel three of them were not working. Check if they are working or not. TDA 8947J is the power amp ic, download the datasheet.
You can also check the input PINs there are article about it.
After I replaced the 3 bad opamp, worked fine like new.
tip
DELL A425 SUBWOFFER PINOUT
CABLE PIN OUT
PIN 1 SPEAKER 1 PIN 5 SPEAKER 2 PIN 3 INPUT 1
PIN 4 INPUT 2 PIN 8 EXTERNAL VOLUME CONTROL PIN 2-5-7-9 GRD
PIN 8 MUST TO GROUNDED FOR MAXIMUM VOLUME OUTPUT
I need the millivolt output recommendation
You are talking about a Meter to measure the Voltage and Amperages. If you do not have one; and need to measure the power, current, or resistance values; take the speaker to Radio shack and they will do it for you.
I have the sub woffer only would like to use on my comp
No problem....just plug the subwoofer into your Green Port on the computer sound section. The Right and Left channel will merge into a monaural sound and come out of the speaker as if you were listening to music from a radio.
8helpful
Wireing diagram for Dell A525 Zylux Multimedia Computer Pc Speaker System W/subwoofer 2.1
pin 1-G
pin 2-R in
pin 3-L in
pin 4-PG
pin 5-R out
pin 6-ST BY
pin 7-VC
pin 8-L out
pin 9-PG
Hi, They suddenly stopped working, think I
Try another speaker set.
If this does not fix it, then consider the sound card if it is removeable, get a new one. If it is internal, turn off the sound and install a sound card.
3helpful
2answers
One speaker is MUCH louder than the other
It sound like you have a break in the main wire from the computer sound card to your speaker amp OR the plug is not plug in completely plugged in all the way. Try some other speakers or ear buds / head phones to isolate sound card problem or speaker problem.
2answers
A525 speakers giving cracking sound /disturbance
contact dell support and get the same replaced
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
