Question about HP Compaq Evo Notebook N600c
Laptop wont start no lights
Suddenly my laptop is not starting we connected to the power but still no lights for charging status o nothingy wife says that when you put sideways the laptop it will eventually start but i dont thinks so. I think it has to do with the battery...please help
  • 120 Answers
Check the power jack inside the laptop that you plug the cord into. Can you jiggle the cord? It's possible the power jack inside the laptop has broken off the motherboard. The reason I suspect that is the fact your wife says it works sideways. It's possible when she is holding it sideways the broken part is sometimes resting on the board just right to make the connection. Unplug the cord and take something small like a q-tip and see if you can move the power jack around inside, or if it's even still there where it should be. The computer would be able to turn on without a battery plugged in as long as you plug it into a wall. If you take the battery out and it still doesn't kick on then you can rule out any problems with the battery. Take a look, if you discover the power jack to be broken like I suspect it may be you're going to have to take it to a repair shop to have a replacement soldered in. You can actually defer some of the cost of this by purchasing the replacement dc jack yourself. You can find them on ebay for very cheap. just type in your brand and model laptop dc power jack and you should fine a ton of them. Then just take it to a computer shop and they should just charge you 1 hour - 2 hours labor depending on the shop. I hope this has explained your question in detail. If I've helped you please don't forget to rate me. Peter
Posted on Oct 04, 2007
Laptop lost battery back-up suddenly.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 06, 2012 | Acer Aspire 5810T-8060 Notebook
Advent modena m200 will not turn on or charge.
Connect the AC power adapter to the laptop and confirm that the AC power indicator is on (I wish you stated the brand of laptop). If the AC power indicator is not on, try and get a working AC power adapter for your laptop and connect it to your laptop.
With the AC power adapter connected, you can power on your laptop. If the laptop powers on from the OS you can see if the Battery is charging or not.
If the laptop does not power with the AC power adapter connected, then the power port of the laptop is bad.
However, if all these are okay and the battery still does not charge, the battery is faulty and will need to be replaced.
May 15, 2012 | Advent Computers & Internet
My compaq presario v3500 wont turn on again. i was using it, watching movie then it suddenly shutdown. my battery is fully charge and the charger was connected. so i try to turn it on and it wont start....
Remove the Battery and press power on for 1-2 minutes with out AC power .
Please turn on the laptop with only AC POWER (without battery ). Check it. it may turn on your laptop.
If display ok, then insert battery and use it...
Jun 18, 2011 | HP Compaq Presario 2200 Notebook
I am using dell inspiron laptop with the following spec 320 GB hard disc 3 GB ram 2.4 GHz speed my laptop works well even the charge is good but ...
has ever been opened?
-remove the AC power.
-remove the Battery
-remove the Hinge Cover
-remove the Keyboard
-left down the"keyboard" you will find a flat cable to be connected to the motherboard.
good luck!
Mar 07, 2011 | Dell InspironTM 1501 Notebook
The battery light flashes alternately blue and amber everytime i turn on my inspiron 1420 (even when cool). I've done a health check using the check button on the battery. Indicates battery status fine and...
Hi justlai33
Not to worry, it is a normal process when any laptop is started. It first check if it is connected to power and starts charging if connected to power.
As far as battery life status is good and fine, you can continue working on your laptop.
You will get a pop of notification when the battery life about to end, till then you can work with out any tension.
Thank you
Jan 02, 2011 | Dell Inspiron 1420 Notebook
Battery wont charge and laptop wont start using
Check the pin inside the connection (end of the cord) which you put into your machine, or check if the power connection on the circuitboard is damaged (you are able to wiggle it a little bit around)
Dell computer use the pin inside the connection from the adapter to recognise if the adapter you are using is a dell adapter or not. If the pin is damaged, or you are using an adapter from another brand. You will not be able to charge, but only power your pc.
Jan 04, 2010 | Medion Computers & Internet
My T42 suddenly wont recharge the battery or wrk off mainsadapter
If the Laptop wont work off the power adepter, it also will not charge. The adepter could be bad (even if showing a power light) or the connector on the laptop could be broken. The best test is to take the battery out, attach the power adepter and try to start the computer if it starts, your battery is at fault. If nothing, suspect eh charger first. Be sure the pin on the Laptop power connector isn't bent or broken.
Jan 04, 2009 | IBM ThinkPad T42 Notebook
Laptop won't start-up
Can you tell me if the status lights on the power adapter and/or the battery turns on? Because you are telling me the status lights only stay on for 30 seconds, this should be a power connection problem.
One other possibility: can you tell me the climate environment of where you use your laptop?
Nov 16, 2008 | Dell Inspiron E1505 Notebook
No power
Unplug All External Devices Unplug the AC Adapter From the Wall Outlet. Disconnect the AC Adapter From the Laptop Reseated the power cable to the adapter.
Remove the Battery Connect the AC Adapter Directly to a Known Good Outlet, But Not to the Computer Verify That the AC Power Adapter Has a Solid Green or Blue Light.
The AC adapter status light is solid green. The AC adapter status light is solid green.Press the Power Button and Check for POST. Post means if you see the dell logo,remove the battery, plug the ac if still it wont turn on or doesnt have any light,Reseat the Memory if after reseatting the memory still the same problem it might be a bad motherboard.
Oct 23, 2008 | Dell Inspiron XPS M140 Notebook
My laptop amilo m-6100 wont start up
although I never tried it, I dont think you can operate a laptop with no battery, even when its connected to AC.
Jan 02, 2008 | Fujitsu AMILO M-6100 Notebook
HP Compaq Evo Notebook N600c Logo
81 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
